reelnative
- Joined
- Jun 14, 2011
- Messages
- 231
- Location
- sw florida
- Tractor
- ford 3500,cat 416 w extenda hoe,bobcat 853,john deere110,kioti 3054, taskmaster 426e
hey bob after i posted that i ate a sandwitch and then went back out and drained all the fluids pulled the head again and the pan and took out piston one and no3 the center piston had good comp so i didnt mess with it, when i pulled out piston 1 i gave it a quick look and saw a ring no3 from the top fully compressed  and stuck, the oil ring no 4 was in 2 pcs and ring 2 from the top was stuck on one side but hay ring no 1 was good hahah, so on to piston 3 pulled it out and all the rings looked good at first but there was a pc of the piston land between ring 1 and 2 fell out and then i pulled a bit on ring 1 and it broke and so did all the others and 2 more piston pcs came out between ring 3 and 4, so i went back to piston one and washed it off in some diesel and sure enough it had 2 cracks in it between ring 3 and 4, i started playing with the rings and ring one came off ok but none of the others did they all fell apart likepot metal, and a few pcs of the piston came off between the rings also so at the least im gonna need 2 pistons and 2 sets of rings, the pistons looked good no diecolor or wear on the skirts, the bottom jurnal berr on piston one had some slight marks on it but the top was good and one side of the crank had a little discolor but it was smooth so ill prob get another set of main berr for that piston also, well all the mystery is over, I was very lucky that i could get to the pistons from the bottom
