PTO shaft how do you keep it off the ground ?
   / PTO shaft how do you keep it off the ground ? #1
RAYJAY
CLIFFORD PA
LS 3039H
HI what does every one do when your mower /other implements are not hooked up i hate laying the shaft on the ground how does every one hold there up ?/
Jeff
   / PTO shaft how do you keep it off the ground ? #2
I have used hooks to hang them off of the implement itself. Sometimes, I will use nylon rope to tie them up.
   / PTO shaft how do you keep it off the ground ? #3
A loop of thin chain or rope seems to work for me.
   / PTO shaft how do you keep it off the ground ? #4
Never worried about it.
   / PTO shaft how do you keep it off the ground ? #5
Bungee cord some, others I use the chain that is on the shaft guard that keep it from turning when in use. In both cases I have it from the top link connection point.
   / PTO shaft how do you keep it off the ground ? #6
I do the same. And I try to keep the shaft angled down slightly to keep the moisture drained out.
   / PTO shaft how do you keep it off the ground ? #7
Same here, But it is in a building now so no rain on it.
   / PTO shaft how do you keep it off the ground ? #8
I have a board I set mine on. It is just enough to keep it out of the dirt.
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
UNUSED RAYTREE RMBD72-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
1995 Rinker Captiva 190 (A53472)
1995 Rinker...
378812 (A51573)
378812 (A51573)
2007 Ford Taurus SE Sedan (A51694)
2007 Ford Taurus...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A51246)
2016 CATERPILLAR...
