PTO shaft how do you keep it off the ground ?
   / PTO shaft how do you keep it off the ground ? #11
bungee cord to hold it upright when stored with plastic coffee can on end.
   / PTO shaft how do you keep it off the ground ? #12
I spray the end good with spray grease then put a plastic Baggie over and hold up with a bungee
   / PTO shaft how do you keep it off the ground ? #13
Bungee cord some, others I use the chain that is on the shaft guard that keep it from turning when in use. In both cases I have it from the top link connection point.
Ditto.
Has the added benefit of keeping the inny from dropping out of the outy on the chipper & tiller shorty shafts. This is really helpful if I am just picking the implement up & moving it to another location.
   / PTO shaft how do you keep it off the ground ? #14
Bought a Bush Hog brand. It has a bracket to one side to cradle the shaft when not attached to the tractor. Brilliant!
   / PTO shaft how do you keep it off the ground ? #15
My fertilizer spreader and my finish mower have quick buttons on both ends. If I was thinking I would store both shafts in the garage. I have used the shaft guard chains to hold up the shaft.
   / PTO shaft how do you keep it off the ground ? #16
I use a bungee cord and spray the splines with Fluid Film.
   / PTO shaft how do you keep it off the ground ? #17
Set the end on a short chunk of log and cover shaft/u-joint with piece of aluminum roofing rolled like rain gutter.
   / PTO shaft how do you keep it off the ground ? #18
many have a safety chain you can click to the aframe.. that or a bunji works fine..
   / PTO shaft how do you keep it off the ground ? #19
Same here.
   / PTO shaft how do you keep it off the ground ? #20
A coat hanger... slide the shaft end through the coat hanger and hang it from the top link attachment point. Upon first use, the coat hanger will go through a slight contortion/flexing (from the weight) and then you are good to go. Once that happens, mine almost perfectly lines up with the PTO output shaft on my tractor making backing into the implement a breeze.
2016 Atlas V4 Towable Light Tower (A51691)
2016 Atlas V4...
Pallet of (4) 10 Lug Misc Wheels (A51573)
Pallet of (4) 10...
2018 John Deere 8270R MFWD Tractor (A53342)
2018 John Deere...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
