Gun for the wife
   / Gun for the wife
I have a Ruger Mark ll target with a bull barrel. An extremely accurate gun when shot off sandbags. A little more accurate than the my K-22 when shooting off of sandbags. When shooting off-hand I can shoot the K-22 much better than the Ruger target model. The K-22 is balanced perfectly and fits my hand so much better than the Ruger.
   / Gun for the wife #42
Check out at Sig P238. Packs a little more punch than a 22. But very good for small hands.
   / Gun for the wife #43
They even have one with a laser sight.
   / Gun for the wife #44
A significant issue I have with a .22 rim fire is reliability. Okay.. I shoot cheap brick packs but I have had 20 FTF to one FTF center fire 9mm. Actually..... I have never had a FTF in 9mm. misfeeds and FTE but never a failure to fire. And I've shot thousands of the cheapest 9 mm I can find.
Perhaps a .380 auto will please your wife.
   / Gun for the wife #45
You are correct, that is the one drawback of .22 rimfire, the misfire.. but you can mitigate that somewhat by using the higher quality rounds. There is a difference.. The cheap bulk packs have the most failure to fire rounds in them. Factory center fire rounds, rarely don't go bang. I have seen a few reloaded center fire rounds not go bang the first time, but it is usually because the primer was not seated correctly and the priming pellet was not crushed enough to sensitize it. Or.. I have seen a primer seated backwards a time or two...ooops.
   / Gun for the wife
The misfires that I have had with .22 rimfire ammunition are so very rare that I don't even consider that a factor. I buy CCI Green Tag first if I can find it. And Remington Target when I can't. These don't misfire.
   / Gun for the wife #47
Gun for the wife?
Good trade. What did you get?
   / Gun for the wife #48
Gun for the wife?
Must be something about SW Washington that causes a mind to function in that manner.:laughing: I was wondering the same thing.
Smilinjak
   / Gun for the wife #49
i love my p238 essentially a mini 1911.. slide lock and all.
got the limited Z edition. ;)
   / Gun for the wife #50
I'm also an advocate of those small caliber semi-autos with tip up barrels. For a person with limited use or strength in their hands, it's a viable option.
Personally, I'd go with a center-fire (that is, .32ACP or .380) rather then a rim-fire.
WOODS TBW15.40 LOT IDENTIFIER 228 (A53084)
WOODS TBW15.40 LOT...
MALONE 3000TP LOT IDENTIFIER 214 (A53084)
MALONE 3000TP LOT...
MURRAY 21" GAS MULCH OR BAG PUSH MOWER (A51248)
MURRAY 21" GAS...
2022 JLG R3246 ELECTRIC SCISSOR LIFT (A51247)
2022 JLG R3246...
Kubota SVL95-2 High Flow Cab Skid Steer (A53472)
Kubota SVL95-2...
