A(nother) Home in the (different) Woods
   / A(nother) Home in the (different) Woods
Been too busy to post. Here are some updates in order:
Shop slab pour:
Pouring_shop_slab%u00252520%u002525284%u00252529%u00252520%u00252528Medium%u00252529.jpg
Pouring_shop_slab%u00252520%u002525285%u00252529%u00252520%u00252528Medium%u00252529.jpg
Pouring_shop_slab%u00252520%u002525288%u00252529%u00252520%u00252528Medium%u00252529.jpg
Pouring_shop_slab%u00252520%u002525289%u00252529%u00252520%u00252528Medium%u00252529.jpg
I have gotta get me one of these!
Shop_slab_pour%u00252520%u002525282%u00252529%u00252520%u00252528Medium%u00252529.JPG
Shop_slab_pour%u00252520%u002525283%u00252529%u00252520%u00252528Medium%u00252529.JPG
Shop_slab_pour%u00252520%u002525284%u00252529%u00252520%u00252528Medium%u00252529.JPG
Final product
Shop_slab_pour%u00252520%u002525285%u00252529%u00252520%u00252528Medium%u00252529.JPG
Then the framers started on the SIPs walls. Took 3 days for the 32x80' shop walls:
Then roof trusses and roofing
shop_trusses_complete%u00252520%u002525282%u00252529%u00252520%u00252528Medium%u00252529.JPG
Then I installed the meter socket and main panel
Meter%u00252520and%u00252520panel%u00252520%u002525281%u00252529%u00252520%u00252528Medium%u0025.JPG
Meter%u00252520and%u00252520panel%u00252520%u002525285%u00252529%u00252520%u00252528Medium%u0025.JPG
And the power co eventually connected the power (what a bunch of slackers - they were even sleeping in their trucks at 9AM!)
power%u00252520connections%u00252520%u002525281%u00252529%u00252520%u00252528Medium%u00252529%u0.jpg
And some soffit
And garage doors
   / A(nother) Home in the (different) Woods #123
Wow, went up fast! I see plywood was used on the one outside wall, any reason for that?
   / A(nother) Home in the (different) Woods #124
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=332657"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=332654"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=332655"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=332656"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=332658"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=332659"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=332660"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=332661"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=332662"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=332663"/>
And some soffit
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=332664"/>
And garage doors
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=332665"/>
Looks good!
Any reason you put the doors on the short wall?
Good eye, Pixguy. That one side is actually made from foundation SIPs panels instead of the regular above-grade type so it has treated plywood on the outside and treated studs inside it. They just finished backfilling on Fri (no pics yet) but that wall is now below grade about 4-5' now. That had to do with the hillside it was cut into and how it all fit.
That is the same reason for the doors on the end - I was a bit constrained by the site location here in that I am close to the setback limit and trying to work in a flat spot (well flatt-ish - there is no "flat" on this lot). This was how it fit. Plus the design has it broken into a front garage section and a rear shop section, and that is the garage section up front (for tractor and my truck). There is another garage door on the long edge, on the downhill face for easy shop access with tractor or whatever.
   / A(nother) Home in the (different) Woods #126
Looks nice , I see why you haven't posted in a wile.
How thick are the walls and what is thr R value?
How will you finish the exterior?
Dave
The foundation panels are 8" thick, and the rest are 6". R value is a difficult question as the straight R value is 6" of expanded polystyrene so R 24ish (~R4/inch), but the real beauty of the system is that it is continuous and very air tight. Unlike framed construction, there are no thermal breaks in the panels except at the window & door openings where the trimmers are installed. The foundation panels are a bit different as they have thermal breaks in them for the support structure (the green treated studs) so I am not sure of the total R value there.
This is the panel supplier I am using, if you are curious. There are others around as they tend to be regional due to shipping costs. Enercept Structural Insulated Panels (SIPS) The Builders' Choice | Enercept, Inc.
You can see the exterior finish in the electric meter install. It is LP smartside stucco panel, which will then be painted. I am using 1x4 sleepers as an air spacer behind that for extra rainscreen-type protection.
   / A(nother) Home in the (different) Woods #128
Thanks, I thought they looked like Enercept panels, I never thought about using them for a shop.
They are manufactured in Watertown SD, I grew up near there.
Dave
   / A(nother) Home in the (different) Woods #129
I want to use SIPS for my roof but haven't found a supplier in AZ yet.
   / A(nother) Home in the (different) Woods #130
Oh yeah, it's looking really good!
2014 Ford F-250 Ext. Cab Pickup Truck (A55852)
2014 Ford F-250...
2006 FREIGHTLINER CST120 TANDEM AXLE SLEEPER TRUCK (A54607)
2006 FREIGHTLINER...
2025 JMR 40in Single Cylinder Grapple Skid Steer Attachment (A55787)
2025 JMR 40in...
