wedge40
- Joined
- Oct 8, 2007
- Messages
- 2,197
Now we need photos of ground up stumps.
Wedge
Wedge
Yes, lots of pics! And good job for sticking with it! :thumbsup: Sometimes it takes looking at what has already been done and rechecking everything. It can happen to anyone. For future reference try marking where each wire that you remove goes with tape and your own hand written diagram to help keep it all straight, otherwise the wires choose their own fun games to play!Now we need photos of ground up stumps.
Wedge
Here is what I am tslking about. The left red wire runs up to the key switch.
I blame the forumrunner software if the is sideways.there are no options to rotate.![]()
Good luck- be safe!
BTW, change the hydraulic filter and date it too, with magic marker. Check the color and smell/consistency of the hydraulic fluid, and find out how often it needs to be changed, filter and fluid.
There should be a wire from the battery under the red wire terminal.
The red wire supplies 12v to the switch, maybe through a fuse. Check and see if there is 12v at the B+ terminal, this is a must. When you turn the switch to the spring loaded start position, you provide 12 volts to the blue terminal.
The blue wire is the start wire and caused the solenoid to energize.
I don't believe you have told us that you have 12v on the red wire to the switch plug or switch terminal.
there were a few weeks of time between pulling the old starter out and replacing with the new one and in that time I forgot which went where so yeah a picture or drawing would have saved a lot of time and frustration. when I hooked them up I was looking for paint/bare metal pattern and it looked right based on that but of course it was wrong.
good call on the hydraulic fluid/filter since they are probably original (only 33 hours on the machine). i'll make sure to post up some pics and maybe video too. man that thing purrrrs now, the sound of a running engine never sounded so good.![]()
I'd use OEM filters, especially for the hydraulics, just to be safe and to make sure you have the right ones.
So do you now have an extra starter and ignition switch for future use if need be?
How'd you end up with this low hour grinder? Are there any more where it came from?
If not, how much do you want for it?:confused3:
<snip> ...but if he ever does sell it, i'm first in line. I have a personal connection with it now.![]()
