MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,643
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
My newly installed remotes also cause TnT tilt cylinder leak-down.
Next time I use the tractor, I'll try plugging the tilt cylinder into the 3rd (non-float) valve outlets and see what effect that has.
I know that I'll lose float (duh) in that cylinder, but for brush hogging, who cares?
If the leak-down persists after the outlet swap, I'll start work on a quick disconnect check chain for the tilt side.
This would allow me to level the deck, old school, with the turnbuckle lift link that I moved to the left side when I installed the tilt cylinder.
2 things, may I ask if you have the Kubota valves? If the switching of the valves does not work, for work that does not require constant adjustments, just un plug the hoses and the cylinder will stay in place. (should)
