Removing PTO shaft from Caroni?
   / Removing PTO shaft from Caroni? #31
Mine is 1 3/8 bore. After watching the video I have 25 1/2" from the pin hole to the center of the hitch pins. On the tractor it is 19" from the end of the PTO gear to the center of the hitch pins. Subtract the 2" and I need a 42.5" PTO shaft. The one I have uses the button at the tractor side. No experience with the collar type.
Well now you know what you need, and it sounds like a La Magdelana. Sorry mine would not work.
   / Removing PTO shaft from Caroni? #32
I noticed in your signature line, some mention of "this girl"... are you a girl?
Yes sir, I am woman, hear me roar :laughing:
Just a woman in a man's world. As always :drink:
Y'all really helped me out with this. Hopefully I won't be a pest.
   / Removing PTO shaft from Caroni? #36
No problem, glad to help if I can.
James K0UA
   / Removing PTO shaft from Caroni? #37
Ejeffras,
I have ordered PTO shafts from Surplus Center dot com
They have been satisfactory and have been heavier than expected.
I recently priced a shaft at Surplus Center for $99 plus freight including a slip clutch to protect the implement.
The MFR of the implement wants $598 for the same piece.
They are worth a look. Just remember that the UPS driver will be in a bad mood that day, mine was because they had been stepping over that heavy box in the floor of the truck all day! LOL.
Have fun with the tractor!
James
   / Removing PTO shaft from Caroni? #38
I wonder if this one would work for you. it says it is 1 3/8 6 spline on the tractor end, and is 35 Millimeter smooth with a 13MM hole for the shear bolt. 35MM equates to 1.37795 inches. which may be pretty close to what you need on that mower.. you need to put your dial calipers on the smooth shaft and see if this one would work. Of course the 13MM hole would be just perfect for a 1/2 inch grade 2 shear bolt. They also had some for 1 1/4 smooth also.
Surplus Center - 35 HP 39.6" TO 52" PTO SHAFT 1.375 6T/35 MM SMOOTH
James K0UA
   / Removing PTO shaft from Caroni? #39
Just another little note regarding the PTO shafts. The three lobed "shaft" is inserted the casting that has the universal joint on it.
If you look at the casting where the shaft ends and the swivel coupling begins, you will see a small hole. That hole has a "roll pin" inserted in it. If we have the correct size punch, we could hammer on the punch and drive out the roll pin.
insert new shaft stock only and save some $$$. just saying...
It all depends on the time available and how worn out the yokes are. (just replacing what we broke.)
Oh, and we need a source for your PTO shaft stock. It would be better handled in person if a farm supply store or even a dealer is relatively local. that way the shaft is the correct diameter for the existing parts.
Happy tractoring!
James
   / Removing PTO shaft from Caroni? #40
I looked at agri supply and on the "welcome page" they had plain PTO shaft stock. If the ends are good, that's cheapest.
I do not know what size #1 is, but the 59 inch section is #33049 and $32.49
The mate to it is 33057 and it is $24.49
If I had those and they were the right size, I might even get a muffler shop to fab it up for me.
I adjust my PTO shaft length with a 4 inch grinder and a pair of goggles. Much faster than a hacksaw.
Let us know how you decide to make it work.
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
3Pt 4' Harrow (A59814)
Freighliner Tender Truck (A56438)
Freighliner Tender...
2004 JOHN DEERE 310G BACKHOE (A60429)
2004 JOHN DEERE...
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
