electrical connectors
   / electrical connectors
All viable suggestions and I probably will pull that snap ring off and just solder a mod on that pin. Thanks for all the help.
I do not want to make a suggestion that will lead you down a black hole.
But WORST case senerio:
I do see a snap ring at the base of the connector on the tractor and a plate that can be removed on the side.
If you truley cannot get the replacement parts, there is a possible workaround.
Without knowing what is inside it is hard to guess further.
Can you ger a parts view of the innards?
I dont think it would hurt to pull that out, but I am going to see if I can find out whats under there if possible.
   / electrical connectors #13
Pictures are out of focus but when I first saw it, it appeared to be weatherpack connector that I see on GM vehicles... replaced the 4wd actuator on my daughters 94 chevy pickup last year and that connector looks similar..
I
I'll check into that hawkeye, thanks
   / electrical connectors #15
   / electrical connectors #16
Namz Custom Cycle Products Deutsch SEALED Connector Black 8 Socket Plug DP8B | eBay
could this be it a Deutsch Sealed Connector ? I cant see the plug well enough to tell.. You might try taking some different pictures. The one good photo on the transmission looks like this might be it, and it is 8 conductor not 6. Obviously weatherproof high quality automotive type connector.
Kubota uses a connector that looks like that near the back of the seat in the L3830, so that could also be the case here.
Aaron Z
   / electrical connectors #17
Well it really is an 8 pin , though it only uses 6, I mistakenly call it a 6 when it is an 8 pin so you might have found it, i'll let you know.
Thanks
   / electrical connectors #20
If it's an 8, which your pics verify, then clean up the plug area, pop the snap ring, wire it up using one of the unused pins in place of the broken one, and away you go. As long as the wire in question goes from socket side to male side same pin you're good.
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A55851)
Miller Trailblazer...
2018 Dodge Grand Caravan SXT Van (A53424)
2018 Dodge Grand...
UNUSED FUTURE MINI PALLET FORKS (A57193)
UNUSED FUTURE MINI...
CRAFTSMAN TABLE SAW (A54757)
CRAFTSMAN TABLE...
LANDHONOR BS-12-2500G (2) PRONG HAYSPEAR (A57193)
LANDHONOR...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A52377)
2008 24ft...
