Storing post hole auger?
   / Storing post hole auger? #11
If you're gonna be leaving it outside, just drill a hole and unhitch n go. Doesn't cost a thing.
Wr have stored like this for years, never had any trouble with auger bits. LUTT
   / Storing post hole auger? #13
Brian, is the down pressure kit universal? If so, where are they available and how many $$? Thanks.
Best to get a unit built for your PHD. Seems like each manufacturer is just a little bit different. So best to look at a dealer that sells your brand of PHD. I have seen costs from $400-$600.
   / Storing post hole auger? #14
LIKE THIS
   / Storing post hole auger? #16
I made an easy one using a wood pallet and 2 2x4's plus an old ground rod. I like it cause i can move the entire thing with the forklift.
   / Storing post hole auger? #18
Great idea! Dose the cyl make a big difference!?
If you are referring to the down pressure cylinder for the PHD, I kid you not when I say that it has saved me countless days of drilling time and I don't even drill that many holes.
   / Storing post hole auger? #19
I made something like MtnViewRanch but built it on a pallet like grsthegreat did.
   / Storing post hole auger? #20
View attachment 349759 View attachment 349760 View attachment 349761
hay..that looks familiar :laughing:
i just love the fact that i can move it around with the forks when shifting my storage area around between winter and summer use. I have so many implements that i have to swap those needing immediate use up to the front, and those that can be mothballed for 6 months to the rear.
pallets make it an easy chore.
New Holland 650 Hay Baler (A53317)
New Holland 650...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
SHOP CAGE WITH CONTENTS (A55745)
SHOP CAGE WITH...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
BUNDLE OF 4" - 6" X 12' BUILDING PURLIN (A54757)
BUNDLE OF 4" - 6"...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A54815)
2008 KZ Sportsman...
