Storing post hole auger?
   / Storing post hole auger? #11
If you're gonna be leaving it outside, just drill a hole and unhitch n go. Doesn't cost a thing.
Wr have stored like this for years, never had any trouble with auger bits. LUTT
   / Storing post hole auger? #13
Brian, is the down pressure kit universal? If so, where are they available and how many $$? Thanks.
Best to get a unit built for your PHD. Seems like each manufacturer is just a little bit different. So best to look at a dealer that sells your brand of PHD. I have seen costs from $400-$600.
   / Storing post hole auger? #14
LIKE THIS
   / Storing post hole auger? #16
I made an easy one using a wood pallet and 2 2x4's plus an old ground rod. I like it cause i can move the entire thing with the forklift.
   / Storing post hole auger? #18
Great idea! Dose the cyl make a big difference!?
If you are referring to the down pressure cylinder for the PHD, I kid you not when I say that it has saved me countless days of drilling time and I don't even drill that many holes.
   / Storing post hole auger? #19
I made something like MtnViewRanch but built it on a pallet like grsthegreat did.
   / Storing post hole auger? #20
View attachment 349759 View attachment 349760 View attachment 349761
hay..that looks familiar :laughing:
i just love the fact that i can move it around with the forks when shifting my storage area around between winter and summer use. I have so many implements that i have to swap those needing immediate use up to the front, and those that can be mothballed for 6 months to the rear.
pallets make it an easy chore.
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
10 GALLON SANDBLASTER (A54757)
10 GALLON...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
Heavy Duty D-Ring Shackles (A55852)
Heavy Duty D-Ring...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A55787)
2017 Toro Z-Master...
