Tractor Lean-To Project (and checking to see if you can link a Facebook Photo Album)
   / Tractor Lean-To Project (and checking to see if you can link a Facebook Photo Album) #11
Thinking you need a support half way across the wall. It'll sag after a few years..
Im in the process of getting mine up too, though more machine shed than lean too.. prolly 24'x18'.... Found 54 sheets of white pole barn siding on the road a couple years back :thumbsup:
   / Tractor Lean-To Project (and checking to see if you can link a Facebook Photo Album) #12
That is not the way the tin will drain, but I did it that way after getting the rafters up and realizing that there was no way to support where the two tin pieces joined together. I couldn't think of an easy way to join the edges. I thought about caulk and about drilling and riveting.
Add one more rafter :)
I wouldnt worry about it though, the metal car ports are ran the same way and they drain..
Its hard to tell in the pictures, but there is close to a 10 inch difference between the shed side and the support side. But, how exactly to you mean to "add one more rafter." Can you do a simple illustration? In some things I'm like an Army man - I need pictures. (I was Air Force by the way). (Edit: should mention that there are actually 6 panels on the roof, 4 metal and 2 poly)
I have some paving stones that I removed from around our patio. One of the previous owners had a thing for paving stones and lava rocks. One of those might do as a base and I have a couple of 4X4 pieces that were trimmed off the top. That should help it blend in. Thanks for mentioning that.
   / Tractor Lean-To Project (and checking to see if you can link a Facebook Photo Album) #14
I meant to add a rafter where the seam would fall..
   / Tractor Lean-To Project (and checking to see if you can link a Facebook Photo Album) #15
One thing I tell you for sure about them pastic light panels, go buy the replacements now and tuck em up in the rafters.
I swear the people who make those things change em every 3 years just enough you can't get replacements.
You get some good industrial steel strapping, stuff that holds machines on pallets you can bowstring them rafters with steel strap and triple the load capacity. Fellow showed me that trick been doing it for years on light weight trusses he makes. Clever as all getout.
   / Tractor Lean-To Project (and checking to see if you can link a Facebook Photo Album) #16
You could have run 2x4 purlins across (side to side) the rafters on 3 or 4' centers to run the tin the other way
   / Tractor Lean-To Project (and checking to see if you can link a Facebook Photo Album) #17
Hate to be critical but the engineer in me is concerned about rafter sag and wall bracing. How about adding braces from about a foot down the wall to near the center of the rafters?
Did the paving stone and 4X4 to brace in the middle. I dug out a level spot for the paving stone and left it about 1/4inch lower than the 4X4. Then I used a 2X4 to lever it up while my wife wedged the 4X4 in a little. Final placement was accomplished with the flat end of a single bit axe.
   / Tractor Lean-To Project (and checking to see if you can link a Facebook Photo Album) #19
I did 2x4 rafters in Wisconsin at about the same run and slope. Worked fine..
As I said, I need illustrations. A or B
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
2015 Ram 1500 Crew Cab Pickup Truck (A59230)
2015 Ram 1500 Crew...
(2) POLY DRUMS (A52708)
(2) POLY DRUMS...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
2014 KENWORTH T800 HYDRO EXC VACUUM TRUCK (A59823)
2014 KENWORTH T800...
