my kubota rebuild
   / my kubota rebuild #71
A very nice Restore, I thank you for the Pictures.
   / my kubota rebuild
found a semi straight rad hose in the size I needed
cleaning up the steering gear
some of the mount bolts had their nuts seized on
ran tap and die over the bolts and nuts
Loctite
set in place on studs
   / my kubota rebuild #73
The photos are so clear and detailed it really tells the story.
   / my kubota rebuild
thx!
so did a little tonight...
rusty metal primer on some bare metal on steering gear
then Kubota blue
then onto more hyd lines...
this one was tough, as it was squeezed in there tight
then got the other side that goes to the cooler
power steering hyd return line...
then got the hard line onto the power steering..thankfully I didn't bolt down the steering gear, as I had to rock it back to get everything started and bolted up...
my dog "buddy" keeping me company the whole time
more later
   / my kubota rebuild #75
Great job that's well documented. Keep an eye on Buddy---my dog used to steal parts.
   / my kubota rebuild #76
Very good thread, Thanks.
   / my kubota rebuild
ha, my other dog max, and Australian cattle dog, used to steal tools.
but hasn't for a long time now...
   / my kubota rebuild #78
I bet. Probably hard on the teeth.
   / my kubota rebuild #79
My dog used to watch me for extended periods of time. You know, looking for a scratch or whatever. The minute my back was turned he would make off with the goods.
   / my kubota rebuild
that is funny...He probably just wanted more attention, ha ha
well been working on some other stuff and traveling a little...but the great thing is that I haven't stopped thinking about the tractor...and couldn't wait to get back to it
I test fitted some stuff as I'm not 100% on how it all goes back together and will have to do some figuring...
the fuel tank sits on a metal shelf, which I painted...
sits about right there, and attaches with four bolts to clutch cover...
then the tank goes on top...
then the center console.
and I seem to be running a tap and die through every bolt/bolt hole on this thing..I hate forcing bolts/nuts when the threads are rusted/clogged
it is coming along, and cant wait to hit it again tomorrow night
UNUSED WOLVERINE TQH-26-02C CLASS 1 QUICK HITCH (A54757)
UNUSED WOLVERINE...
2013 Ford F-150 (A55788)
2013 Ford F-150...
2014 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2014 Ford F-350...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2015 FREIGHTLINER...
2015 KENWORTH T680 SLEEPER TRUCK (A54313)
2015 KENWORTH T680...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A52377)
2017 Mack GU713...
