Millermatic 140 for bucket hooks
   / Millermatic 140 for bucket hooks #41
Bolt down the base plates to play it safe and I think your covered then. That is your most critical area where you were underpowered.
   / Millermatic 140 for bucket hooks #42
Testing the hooks by lifting or pulling something in a controlled environment like you did is a lot better than whacking them with a big hammer. Hooks aren't meant to be beat on and you could cause stress cracks or other unseen fatigue that might cause them to fail. Read about Shield Arcs near fatal experience with a damaged lifting eye if you need some insight.
   / Millermatic 140 for bucket hooks #43
If they're really weldable hooks, they are forgings, and will have no problem being hit with a hammer.
   / Millermatic 140 for bucket hooks #44
What if beating on the hook causes a hairline fracture or under bead crack in the weld you can't see?
   / Millermatic 140 for bucket hooks #45
If it's that suspect, then it should be re-done
   / Millermatic 140 for bucket hooks #46
How does a hammer blow determine how much it will lift, one blow is good for 500 lbs., so two is good for 1000 lbs.?
   / Millermatic 140 for bucket hooks #47
For general around the farm lifting I've even made my own hooks out of 3/8 steel plate, for most small tractors power if lifting it's not a issue in my opinion, if it was a crane or construction equipment that would be a total different ballgame and would never even begin with a 140 amp machine
Progressive Turf Mower- INOPERABLE / PARTS ONLY (A52128)
Progressive Turf...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A50046)
2018 FREIGHTLINER...
John Deere 946 Center Pivot Rotary Mower-Conditioner (A52128)
John Deere 946...
2006 GENIE GTH6622 TELESCOPIC FORKLIFT (A51242)
2006 GENIE GTH6622...
