Skid Steer Grapple on a tractor?
   / Skid Steer Grapple on a tractor? #11
Ken45101 mentioned plumbing. Be aware that skid steer attachments will use a flat face hydraulic quick coupler that is different from ag couplers. So, you'll need to run hydraulic hoses to the front of the tractor, and you'll want to make sure you put the right quick connects on them that will mate up with the skid steer flat face couplers. And you'll have to decide whether to run the hydraulic hoses from the rear remotes or add a 3rd function system. I had my dealer change out the flat face couplers on my grapple to regular ag couplers.
But, to answer your general question, yes the skid steer quick attach system used on full size skid steers (not the mini ones) is the same used on tractor front end loaders with a quick attach. I bought a stump grapple made for a skid steer and it works fine on my tractor. As someone mentioned above, the heavy duty ones could weigh 900 pounds or more and could eat up a lot of your lifting capacity. A lighter duty one could weigh as little as 350 pounds but would likely not be as durable, especially on a larger tractor that could overpower it.
   / Skid Steer Grapple on a tractor? #13
as everyone else has said yes. ag couple are not that expensive i think i got 2 for $24 out the door and i replaced the flat faced ones with them. you could do the same or not. i run mine off the rear remotes and it's plenty fast for me.
my root rake weighs in around 700lbs, lift capacity is 3100 at the pins. i still have plenty left over to move mostly brush and logs
   / Skid Steer Grapple on a tractor? #14
Where did you get the grapple, Pappy? That's just what I need.
   / Skid Steer Grapple on a tractor? #15
Wildkat Attachments
WILDKAT ATTACHMENTS by Mid-State Equipment Buckets, Grapples, mowers, augers, and more for your Bobcat, John Deere, and others!
If you click on "Buy Now", it takes you to their ebay store. When I called them for a shipping quote, they knocked a few bucks off the price shown on ebay. So be sure to ask. It was shipped the same day and my experience with them was very satisfactory.
I haven't used it enough to comment on it much, but it certainly seems to be well built and strong enough. Mine is the regular one shown at $695. They show a heavier duty one on their website, but I think that one would have been a waste of money and lifting capacity for my needs.
One thing I've learned from using it, though, is that I wish the back plate (where it mounts to the FEL) wasn't solid so I could see through it and perhaps see what I'm doing.
   / Skid Steer Grapple on a tractor? #16
Eddie: One other thing I'd do differently next time is mount the quick connects on the TOP of the FEL cross bar instead of the bottom. When the bucket is tilted all the way back, it can contact the hoses at the quick connect. If the quick connects were on top, that wouldn't happen.
I'm gonna have the dealer make that change when I take the tractor in for the 50 hour service.
   / Skid Steer Grapple on a tractor? #17
wildkat makes some decent stuff. no sure i agree on the solid plate though. it would be nice to see but brush or in your case roots coming through the opening could be a hazard. as for mounting the quick connect couplers any reason you didn't do it on one of the loader arms itself?
   / Skid Steer Grapple on a tractor? #18
My Kioti dealer put a piece of light duty angle iron across the cover for the FEL lines, between the loader arms. It uses the factory bolts to hold the piece and then the QDs are attached to the angle, thus raised up a little off the crossbar. It works for my log grapple, in my avatar, and my snowplow.
I'd add a colored cable tie to one female and one male QD to make for easy hookup with no guessing to your rig.
Nice tractor and grapple!:thumbsup:
   / Skid Steer Grapple on a tractor? #19
You should have a male and a female for the third function on the the tractor.
Sent from my Samsung SPH-L710 using TractorByNet
   / Skid Steer Grapple on a tractor? #20
It's not a third function; I have a diverter valve and the hose ends are two female on the loader and two males on the grapple/snowplow. Both rear remotes are two female at the valve also.
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
1994 Chevy  2500 Dually Pick Up Truck (A50515)
1994 Chevy 2500...
CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A50458)
CATERPILLAR D8T...
Bad Boy 31HP Pro Series Mower (A50514)
Bad Boy 31HP Pro...
John Deere Hsld 2510 H Nh3 Applicator (A50514)
John Deere Hsld...
