rd_macgregor
- Joined
- May 14, 2008
- Messages
- 1,874
- Location
- Prince Edward Island, Canada
- Tractor
- Kioti DK45SC, Kubota B2650
I've had my BX62 for three years and used it more this year than any of the previous ones. It took me a while to get over the initial fright of it snatching branches out of my hands and (loudly!) gobbling them down and spitting them out...it is scary, at first!
As for the size of material it will take, I've found that it will easily take 4"-5" softwood, but can choke on hardwood (eg maple) of that size. It almost seems like it self-feeds too fast.
Having said that, my setup has some sort of problem not related to the chipper. When the chipper chokes on something too big and tough, it doesn't shear the bolt, nor (to my surprise and consternation) does it kill the tractor. Instead, the PTO clutch in the tractor starts slippping, and the revs of the tractor drop dramatically. This doesn't bode well for future tractor maintenance, so I've backed off on how large trees and branches I feed into the BX62. I suppose I could use a lower grade shear bolt, but I don't think that's a good solution either.
Anyway, the only other issue I've had is clogging with spruce needles...you just need to run some heavier stuff through with the branches or let them lay until after the needles fall off before chipping.
I don't like carrying tools in the loader bucket (I tend to forget, which ends up badly), so I bolted a chainsaw scabbard to the outside of my chute so I could carry the saw into the woods.
You are really going to enjoy that machine. At least the neighbours will match your chipper when they turn green with envy.
Bob
Bob
