Have both the blade and the grapple here. Like the blade. Not sure about the grapple, had a bad experience, it arrived with all the fittings finger tight so it spewed fluid all over the place.
The grapple just got here, not sure if I like it or not. A neighbor who knows way more than me said I won't like it because it won't hold one tree.
I'm stewing on how to grab stuff. Stay tuned.
What do you mean it won't hold one tree? The nice thing about the open bottom grapple is that you don't need to rely on the clamping force to hold the tree in, but rather the weight of the tree just sitting on bottom of the grapple.
I can say I have never had trouble holding a tree that was too small, now, too big has happened but never too small. My only issue is that I can't lift 3k lb logs but that has nothing to do with the grapple.
I suspect he is talking about "clamping" one tree. That is an advantage of the claw type or 4n1 bucket which will hold a single tree in place for sawing for example. I don't use my grapple like that but if I did I would so as SD455dan said and simply add a few short logs to take up space in the grapple maw and provide active clamping on the one I wanted to buck.
Yeah, clamping is what I'm talking about. Sometimes that's nice. We tend to move stuff a ways and if it bounces around thats not so nice.
Too bad somebody who uses their grapple like you want to do didn't chime in earlier and recommend the RGBD style grapple from W.R. Long.
Any grapple will hold a tree, it's those rascally different sized logs that cause problems!
I see what you mean, but don't think you will need it. If you travel with the grapple curled back all the way, stuff won't bounce out.To answer the question below about my neighbor being jealous, I doubt it. He does construction for a living, has every skidsteer attachment known to man, he's a pro. I trust his judgement.
What I think he is saying is that he's likes being able to clamp down on whatever it is he's moving around. And I can see his point, unless you put enough stuff in the grapple it will bounce around (sort of makes you wonder why someone doesn't make a grapple that could close further doesn't it?) Maybe cause it isn't necessary!
I think I see a way to fix it for times when you want it to close better, still stewing on this but try this on for size.
The shape of the top part is a big L turned sideways 90 degress clockwise, right? Suppose a guy drilled a couple of holes at the two ends of the L and then bolted a bar across the L turning it into a triangle. That would mean it would close down on a smaller log and hold it tight.
If a guy were to drill another hole at the corner of the L, then he could pin the bar parallel w/ the long side of the L (out of the way) with a pin and a lynch pin. Need to grab more? Get out, drop the bars, pin them, get back in. Now your grapple is more like a clam shell grapple that can grab stuff tighter.
See what I mean? If so, what do you think?
How old is your cat James?
