Building a switchback in a road
   / Building a switchback in a road #1
Rio_Grande
I am in the process of building roads through my property. Unfortunately my 15 acres was cut out with a straight edge and a map with little regard to accessing all of it. That left me with 4 hill sides 2creeks and areas so steep you cannot stand without loosing altitude. I cut a road up one of the hills from one of the creeks without much trouble using my ctl70. It isint perfect but the jeep can go up and down it. On one other hillside though I cut downhill and had to make a switch back to get turned and then a 100 yard long chute down into the creek. Next will be to go up the steepest longest biggest hill in similar manner.
My issue is with the switch back on the second described trail. In 20 feet of forward movement there is a 70 deg turn and a 15 foot drop. Needless to say on a dry day it is a white knuckle experience making that part of the road on a quad. The penalty for not making it is a 80 ish foot drop into the creek.
I want my kids to be able to ride quads through the woods and I can't let them on this.
I will get a pic next time I am out there but I was hoping some experienced folks might give me some advice. Budget is small but I have most equipment needed to do a lot of work.
My thought is to cut som cedars and build a retaining wall to hold the outside of the switchback, dig over into the hillside on the top and then make the turn occur right before you enter the Shute to go down.
Not sure that makes sense,
   / Building a switchback in a road #2
Switchbacks on steep hills just require a lot of digging and widening. I've found it easiest if you keep the actual turn flat.
I see no reason for it to be a "white knuckle experience", you just have to make enough room. OTOH, I recently did one switchback where it does require a 3 pt turn but I have plenty of room for that.
A retaining wall may help but it's a lot of work compared to just digging more dirt :)
   / Building a switchback in a road #3
subscribed!
I have 10 acres in western NC that I'm cutting roads through...It doesn't sound as steep at the OP's, but is too steep to drive up with a 4 wheel drive B21.
In fact, I have some pics of a road I'm beginning to cut across one of the hills with a rental B21...
I'm taking dirt from the uphill and just dumping it onto the downhill and compacting with the tractor. So, half of the road is solid undisturbed earth and half if compacted fill.
Of course, what that results in, is the downside of the hill past the new road is now MUCH steeper for about 20 ft or so.
I guess the only way to get around this is to dig further into the hillside and instead of dumping on the downside of the hill...taking the dirt off the property and selling it or something....
we have clay, and it is very stable.....
anyways, I'm interested in this thread and in maybe gleaning some information and ideas
   / Building a switchback in a road #4
Matt, Looks like you are doing an intersection rather than a simple switchback? Yes, those are more complicated because of the change in grade.
In my experience, although you have the fill compacted well, it will still settle for several years. I've started leaving extra height on the fill area so that it will hopefully settle closer to level.
BTW, I originally did work with a B21 but that little machine always worried me on a hillside :) I've graduated to a mini excavator and a skid steer.
Thanks for the replies. It amazes me what you can do with a little tractor. I like the idea of digging Dow as opposed to building it up. Our soil here is clay and settles forever if you don't compact it as you put it down. While possible it would be a lot harder on this particular part of the road than just cutting deeper into the hill. Attached is my machine. I don't think I could do this without it.
   / Building a switchback in a road #6
Your right, that isn't a switchback, but when I get to the other side of the property, about 600 ft or so, then I will be doing a switchback....hence my interest in this thread...
do you think a skidsteer and mini excavator are better on inclines?
To rio grande, I would love to see some pics if you have any.
and if anyone has pics of switchbacks they have done, that would be incredibly helpful also.
thx
I will get some pix this week of what I have currently. I have run both on soaps and am just more confident with my tracked skid steer but I have hundreds of hours of seat time in it. I have about 20 career hours in a track hoe. I have never run a little one.
I hope to get it all cut in soon. We are deer hunting now so I am not doing any excavating. As soon as the deer are all killed as long as rains don't set in I want to. Get back to work.
   / Building a switchback in a road #8
thx
A mini excavator more maneuverability and stability than a small backhoe and definitely more swing. A backhoe is limited to putting the dirt no more than 90 degrees to the side. And it has the dozer blade for pushing and leveling. A skid steer can often work faster (depending on rocks) but needs more width to maneuver. I kind of alternate between the mini-ex and the SS. Of course if you need to move dirt any distance, say for the switchback, a mini ex is very slow compared to a skid steer.
When initially cutting across a steep hillside, I definitely prefer the mini ex over the skid steer. If you don't have room to maneuver a skid steer, it's hard to do the initial cut with one across a hillside although I'm sure some good operators can do it.
Here's one photo of me working across a hillside
You know it is steep when it looks steep in the photo!
I am by far not a pro operator. But to dig with the skid steer I just do the back and forth method going up hill and coming down I can make longer back and forth runs. Coming up hill I find I have to dig the hill out to go up, coming down hil I can cut out enough to move up then when I can't do that I back up and cut to grade. Again I probably am doing it wrong. As always I am looking to learn.
   / Building a switchback in a road #10
uh yeah, that is steep...
love the pics, as sometimes they can tell the story a little easier...
I have a lot of road to cut and dirt to move, and might have to consider doing a mini ex and skidsteer combo rather than a TLB.
I was looking at the L39 Kubota, and it would be the cheaper route for sure...
Pretty much all I have to do is dirt moving and digging. I wont be pulling a bush hog or anything like that...so maybe a tractor isn't the best fit for me.
lots to think about...
John Deere BD1108 (A50123)
John Deere BD1108...
BUSH HOG 2820 LOT NUMBER 125 (A53084)
BUSH HOG 2820 LOT...
(12) 2" X 6" X 41" TUBING (A54756)
(12) 2" X 6" X 41"...
2015 FORD F350 SERVICE TRUCK (A51406)
2015 FORD F350...
2016 CATERPILLAR 313FL EXCAVATOR (A52705)
2016 CATERPILLAR...
UNUSED DIGGIT 20'X30' METAL GARAGE CARPORT SHED (A54757)
UNUSED DIGGIT...
