Ballast Photos
   / Ballast Photos #31
I needed a little ballast when using the 7' brush hog on the front.
The Brush Boss weighs 165 lbs. The suitcase weight is 75 lbs.
Used a scrap piece of 1 1/4 square tube for a spacer.
Now it steers better on side hills, :thumbsup:
   / Ballast Photos #32
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=347527"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=347528"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=347529"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=347530"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=347531"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=347532"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=347533"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=347534"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=347535"/>
What does the brush boss do?
Sent from my Samsung SPH-L710 using TractorByNet
   / Ballast Photos #34
It bosses brush.:laughing:
It hasn't done any thing for me since I sold my tractor 3 years ago. Before that I used it to remove cedar trees.
   / Ballast Photos #35
   / Ballast Photos #36
Ballast.jpg Since this is a "Ballast" thread, I will give you a tease picture and see if you can guess what it will become.
   / Ballast Photos #39
Here is mine. I can just set it down to get rid of it. I made the attachment so I can use my forks as well as the weight. The weight is about 900lbs.
Steve
   / Ballast Photos #40
Steve, I like that you can do a quick drop.:thumbsup:
Here's mine - it's about 500 lbs. The 2 holes are for standing a shovel or rake in. I don't use it a lot because I usually have the snowblower attached all winter and the bush cutter on Ballast Block-.jpgfor most of the summer.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60429)
KNOW BEFORE YOU...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2005 Ford Crown Victoria Sedan (A56859)
2005 Ford Crown...
Stanley Tool Box with Tool (A57454)
Stanley Tool Box...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
