Ballast Photos
   / Ballast Photos #31
I needed a little ballast when using the 7' brush hog on the front.
The Brush Boss weighs 165 lbs. The suitcase weight is 75 lbs.
Used a scrap piece of 1 1/4 square tube for a spacer.
Now it steers better on side hills, :thumbsup:
   / Ballast Photos #32
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=347527"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=347528"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=347529"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=347530"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=347531"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=347532"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=347533"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=347534"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=347535"/>
What does the brush boss do?
Sent from my Samsung SPH-L710 using TractorByNet
   / Ballast Photos #34
It bosses brush.:laughing:
It hasn't done any thing for me since I sold my tractor 3 years ago. Before that I used it to remove cedar trees.
   / Ballast Photos #35
   / Ballast Photos #36
Ballast.jpg Since this is a "Ballast" thread, I will give you a tease picture and see if you can guess what it will become.
   / Ballast Photos #39
Here is mine. I can just set it down to get rid of it. I made the attachment so I can use my forks as well as the weight. The weight is about 900lbs.
Steve
   / Ballast Photos #40
Steve, I like that you can do a quick drop.:thumbsup:
Here's mine - it's about 500 lbs. The 2 holes are for standing a shovel or rake in. I don't use it a lot because I usually have the snowblower attached all winter and the bush cutter on Ballast Block-.jpgfor most of the summer.
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
2018 Nissan Sentra Sedan (A56859)
2018 Nissan Sentra...
CATERPILLAR 255 SKID STEER (A60429)
CATERPILLAR 255...
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
Case IH MX270 Tractor (A59814)
Case IH MX270...
2018 JOHN DEERE 323E SKID STEER (A60429)
2018 JOHN DEERE...
