MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,641
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
I have a N.H. 1510 4WD and I pull a 6.5 foot Edwards Heavy Disk. I am at 30 H.P. and as stated above, you need to pull at 4 or 5 M.P.H . to get a good soil turn. This is at the outside limits of what this tractor can handle. It makes my tractor work at its full capacity. I could make it work easier by taking off 1 or 2 pans, but so far this tractor has been able to pull this disk. You may be able to pull a disk like that but you may have to remove a pan or two. Soil and ground conditions will tell you what your tractor is capable of. My pans are 20 inch, Be flexable and adjust according to what you soil and tractor are able to handle. Maybe remove a pan or two. Good luck. You are going to push that tractor hard with 23 H.P. pulling a 5 foot disk. Keep in mind that you can remove or adjust the pans to be less aggressive and maybe go over the plot twice to get it done right.
If you don't mind me asking, just how heavy is your "heavy disk" ? :confused3: If people can see what the actual weight is, that gives them something to go by vs such a general description. One companies heavy is another companies medium. Just helps people that are looking to better understand. Pictures are a BIG help also.
