Starter problems for a Kubota
   / Starter problems for a Kubota
It was the PTO safety switch.
Thank you all that gave me input.
   / Starter problems for a Kubota #22
Glad it turned out to be so simple. Once you spot where each of them is, you'll know right where to go next time.
f.
   / Starter problems for a Kubota #23
OK cool. Now for the rest of the story. Was the PTO switch defective or out of adjustment? Or did you just forget it was engaged?. Cmon we really want to know.:)
It must of been bumped, getting in or out.;)
   / Starter problems for a Kubota #25
So now you have a extra battery?
   / Starter problems for a Kubota #26
Thanks for the reply. It really helps us help others to know what the failure mode was.
   / Starter problems for a Kubota #27
we have an 2800 manual with same problem. Giggle the wires above the starter solenoid, make sure u are in neutral on range, pto off, and u are sitting in the seat and try starting again. Always put the range in neutral and stay sitting in the seat when u turn off engine.
If starter problem with HTS it is the front back pedal safety that does not make contact with the relay. the relay is under slightly on the left of the ignition switch, push the relay module down (it is loose) and it will make the contact.
   / Starter problems for a Kubota #28
hi new member here also.in my past experiences with starter solenoids if you can start it by using a screwdriver by touching the two poles together and you dont have a fuse in there in the middle then your solenoid is most likely the culprit.rather than just throwing a new solenoid on it pull the starter/solenoid together and take it to the local electric place that rebuilds starters and alternators hope this helps.
RICK
   / Starter problems for a Kubota #29
That sounds backwards. If the solenoid works when you cross the terminals but not with the key it's a switch or wiring or safety problem. Maybe I missed your meaning?
Jim
   / Starter problems for a Kubota #30
Look at the threads talking about the low voltage relay kit, it may be high contact resistance from all the interlock switches. Had similar problem with my G2160.
David Kb7uns
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2013 Ford F-550...
1984 NAVISTAR 1954 CABLE HOIST (A51222)
1984 NAVISTAR 1954...
2006 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51243)
2006 FORD F750 XLT...
2019 VOLVO EC350 EXCAVATOR (A51242)
2019 VOLVO EC350...
Case 721B (A47384)
Case 721B (A47384)
2022 KUBOTA KX040-4 EXCAVATOR (A51242)
2022 KUBOTA...
