Chain saws
   / Chain saws #41
A little off topic.
A couple of years back I injured two fingers on my right hand.
Rope starting was agony.
I bought a Stihl 250c with easy start and have no complaints.
Easy to start... almost no effort on the pull because pulling winds a spring.
The 250c is/was the largest easy start with no tool adjustments for chain tension.
Several neighbors have since bought the 170 with easy start.
Mostly for storm clean up which happens a couple times each year.
   / Chain saws #42
Next saw is a Echo 500P 20" Bar. Or a 450
   / Chain saws #43
I've always had Husky saws but I really like the Stihl pro chains. They seam to keep the initial sharp edge for longer than any other brand I've tried.
   / Chain saws #44
You talking about the chain?
   / Chain saws #46
Went to buy an extra chain recently for one of my Stihls and the guy pulled two possible chains off the rack. I asked to compare price points and one chain was ridiculously high. Turns out it was a carbide chain for firefighters to cut through just about anything! I chose to pass. They told me it could not be resharpened either! Wow, throw away expensive carbide; I'll stick with the regular Stihl chain thanks.:thumbsup:
   / Chain saws #47
I guess everybody's experience with smaller, powerful saws are much different than my own. My Echo cuts continuously without overheating until I have to refill. The tank and chain oil will last a couple of hours which is about as long as I care to saw without taking a break. The chain stays sharp right up until you bury it in the dirt, then I can sharpen it in under 5 minutes, on the saw.
Other than the run time on a tank, that's what I see with my little 170....only 8.5oz tank.
   / Chain saws #48
The Stihl MS290 would be a good saw. If you want a pro grade saw look at a MS261 or MS361. The 361 is a good all around saw, if I had 1 saw that would be the size I would want.
   / Chain saws #49
MS261s are awesome saws. I have one as well as an 026 still in good shape. Both great saws and I don't see any drop in quality from old to new. Less vibrations on the MS261 than the 026, but both are great saws.
I've heard many folks with the same opinion.....almost a cult follwing for the 026, it seems, so I'm sure you're right. It seems to be a really nice balance of size and power. There is a local guy here with a long-running CL ad showing piles of pro series Stihl models. He lists the 026, and I've thought about contacting him to see how much he's asking, or if he has a 260/261.
Saw ****:
STIHL CHAINSAWS FOR SALE
   / Chain saws #50
Saw ****:
I have a 024 Super. The 024 super has the 024 bore (42mm) but the 026 stoke. When I got the saw it was locked up from from being ran with straight gas. I put a MS260 piston and cylinder (44.7mm) in it which is bigger than a 026(44mm). It is a good little saw but it is still not over powered.
I think the MS261 is completely different than a MS260. I think the 261 has .5 more horsepower.
2018 Infiniti QX60 Multipurpose Vehicle (A51694)
2018 Infiniti QX60...
2000 INTERNATIONAL 9200 (A52472)
2000 INTERNATIONAL...
Landoll Hauloll (A52748)
Landoll Hauloll...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2014 Chevrolet Cruze (A51694)
2014 Chevrolet...
48" Pallet Forks  (A52384)
48" Pallet Forks...
