More framing work
Here is showing the Kitchen deck and the front entry porch. You can see they pretty much finished Tyvek on the house too, Eddie. It will go through the winter with Tyvek for siding. They still had to finish cutting out the Tyvek on the 3rd window on the upper floor. This is Mid Oct
Roofer showed up finally on Oct 26 and took 2 days to finish. The first day was Sat and only a few guys showed up and they stood around half the day. It was a crew of Hispanics, which usually go to work like maniacs, so I was surprised to see this. Some of them came back Sun with a larger crew and they really went to town then and wrapped it up. But I am very glad I was there the whole time, or they would have messed up a few things. This was not as simple as the shop roof, so I really needed to keep an eye on things.
Here is a pic after Day 1, I didn't take any on Day 2 - too busy. This is from the upper deck. This worked out nice, as you can just walk right off the deck onto the roof here (you can see the deck corner in the lower left) and basically access the entire roof quite easily. At this low pitch, it is very easy to walk on.
The framers wrapped up and pulled everything out on Oct 24, just before roofing started. While it was nice to have that part completed, it was a bit disconcerting to not have them around after all this time. The main framer guy is a friend to a degree as our daughters go to school together and we have worked well together, so it was always good to have him to bounce ideas and questions off. I can still call when I need to, but it was nice having him there.
A lot of other things were happening at this time too. Oct was the mad rush to get everything in before winter hit. The well got drilled and plumbed in. The pump is in and the line is run inside, but the Pressure tank is not yet in, and we don't actually have water yet. But it's close. Well was 240' by the time they wrapped it up. Here it is, it's a well head, you know what it looks like...
So while the framing was in the late stages, we were getting the basement slab prepped and ready to pour. As previously noted, we did a lot of that during the monsoons in early Oct, but since they had the roof mostly dried in, it was not bad in the basement. So here is the basement with 4" of foam, mesh and tubing in place.
Then they finally came to pour the basement on Oct 18, and it was getting cold. Still not bad enough to be real concerned, but it was getting there due to an early cold snap.
Due to it getting cold they also wanted to get the post footings in for the front entry porch. They brought the bobcat up with the 24" auger for this. Nice to get that out of the way right then too. We put a pretty massive amount of concrete into the holes for those. Went down 8' to get to undisturbed ground at 24" dia. That should hold...
