Snow Equipment Owning/Operating how many are ready for snow in the northeast..........
   / how many are ready for snow in the northeast.......... #51
Well, you're right. I goofed it all up. The snow started out fine, but changed to freezing drizzle. Just checked the radar and it looks like precip will end in less than an hour. At least there's some crusted snow to push around.
Well nothing like I expected. Here in northCT got maybe 4-6" but was very heavy. My new reconditioned plow worked great and took 1/2 the time than last year using a bucket. IMGP2306.jpg
   / how many are ready for snow in the northeast.......... #52
Well I have the hill and three drives all opened up. No sign of the town on their end but I'm sure I heard them rattling by down the road. I'll leave my own drive until they come in as I need to do a four car shuffle and rather do it just once after it finally stops. A good foot of snow but blown around so quite a bit more in low places between snowbanks.
   / how many are ready for snow in the northeast.......... #53
PHPaul.
Like your attitude :) I'll be sending couple plus extra inches your way. ;)
   / how many are ready for snow in the northeast.......... #54
Nice day to be inside!
Might be tomorrow morning before I start clearing, quality seat time :)
Sean
   / how many are ready for snow in the northeast.......... #55
Many UTVs use a winch for lifting the plow. Although winches normally use wire rope, the steady "up/down" required when plowing results in a lot of wear on a short length of the wire rope. It's recommended to use a strap (like some boat winches use) rather then the cable supplied with the winch. Do you use a snow plow on your Gator? If so, how does the chain work? I don't think a chain would work with a winch...not the kind I've seen on UTVs.
My Gator came with electro/hyd lift for plow.
And the rocker switch is in the cab right down by shift, diff lock and park brake for right hand.
The chain provides float.
   / how many are ready for snow in the northeast.......... #56
View attachment 350403View attachment 350404View attachment 350406
The Eagle plow naturally floats as there is no down pressure or rigid structure between the plow and the Gator except where the plow hinges on the mounting plate (that's what the trip springs are for). Lifting is done, as I wrote, by the front mounted winch.
It sounds like your Gator has the factory setup being electric/hydraulic. That's really cool, but I didn't have the extra $2000-$3000 when I bought my 855D.
The plow I bought was used. The seller (a TBN member) bought a Boss plow, which like yours, is electro-hydraulic. $3200, IIRC.
   / how many are ready for snow in the northeast.......... #57
I'll let ya'll know after the snow (12-14 inches) soaks up the rain coming down now how ready I am.
Anyone who wants it can have this proverbial hitting the fan right now.
   / how many are ready for snow in the northeast.......... #58
The Eagle plow naturally floats as there is no down pressure or rigid structure between the plow and the Gator except where the plow hinges on the mounting plate (that's what the trip springs are for). Lifting is done, as I wrote, by the front mounted winch. It sounds like your Gator has the factory setup being electric/hydraulic. That's really cool, but I didn't have the extra $2000-$3000 when I bought my 855D. The plow I bought was used. The seller (a TBN member) bought a Boss plow, which like yours, is electro-hydraulic. $3200, IIRC.
Roy,
I understand the cost the option, mine was $710 in 2000. Just priced a new 850i S4 with the same options my 2000 6x4 has and it was over $32,000. Ouch!!
I have thought of putting two electric/hydraulic units for angle run by the same switch one wired in reverse to simulate a plow truck hyd. However with my heating setup I find myself looking forward to stepping out to cool off to turn the blade. That is plowing in at t-shirt, no gloves and stereo jammin.
   / how many are ready for snow in the northeast.......... #59
Roy,
My 855D is pretty bare bones...the only option was power steering since that was installed before I bought the machine. In retrospect, I wish I'd gotten the windshield...but that will come sometime.
I have added rear work lights (Deere kit) and a warning beacon (aftermarket).
$32K!!! That's more then I paid for the Gator and the 4400 combined! Too rich for my blood!
   / how many are ready for snow in the northeast.......... #60
I've been promised half a foot of snow or more and gotten 0 -1/2" too many times. In South East Michigan in the last 10 years I've found that if I take the forecasted amount subtract 3 and divide by 2. If your left with a positive number that will be closer to what we get
I hear ya. Last couple years all the storms have gone up along the coast. We're north and west of the White Mountains, so we're in a pretty good shadow for coastal storms. The predictions on this storm were 8-12, we got ~6. Nice dry snow, the ATV handled plowing it just fine. Hope we get some real storms, haven't had much seat time since fall.
2012 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A56129)
2012 FREIGHTLINER...
New/Unused Gold Mountain 12ft x 20ft Steel Carport (A54865)
New/Unused Gold...
2018 John Deere 460E Articulated Dump Truck (A55302)
2018 John Deere...
2016 Club Car Carryall 1500 4x4 Utility Cart (A53424)
2016 Club Car...
2013 TAKEUCHI TB235 EXCAVATOR (A52707)
2013 TAKEUCHI...
12in Digging Tooth Bucket Excavator Attachment (A53421)
12in Digging Tooth...
