Diesel confirmed in new Chevy Colorado.
   / Diesel confirmed in new Chevy Colorado. #172
I went to the next town over thinking I would find cheaper diesel, wrong...
4.19 this morning vs 3.49 for regular. That is, if my fingers worked, exactly 20% more for diesel over regular.
And the diesel should have been under four bucks. What a rip.
   / Diesel confirmed in new Chevy Colorado. #173
The larger volume combustion chamber , the lower the ratio of cold combustion chamber wall. Cold metal raises CO and HC.
Yup. So they boost the fuel injection pressure up to 29,000 psi and use multi-injection piezo injectors to rate shape the fuel injection event. Still not good enough....put on Diesel Exhaust Oxidation Catalyst (DOC) & Particulate Trap. More & more $$$$$$$$$$$$$$$$$$
   / Diesel confirmed in new Chevy Colorado. #174
I went to the next town over thinking I would find cheaper diesel, wrong... 4.19 this morning vs 3.49 for regular. That is, if my fingers worked, exactly 20% more for diesel over regular. And the diesel should have been under four bucks. What a rip.
We are at 30%! Regular gas is $2.99 and on road diesel is $3.89. I heard that diesel fuel will be dropping after the first of the year.
I'll believe it when I see it.
   / Diesel confirmed in new Chevy Colorado. #176
Check this table of state taxes on gasoline an diesel. Depending on what state you're in, the tax differential may be a big part of the price differential. Here in blue state CT, diesel taxes are over $.29 per gallon more than gas. They've been raising it by substantial amounts each July 1st for the past few years. Then they turn around and want to convince you CT is a great place to build a business; well not if you need to run diesel equipment of any significance. Being a small state, I imagine the long distance truckers just skip over CT when planning refueling stops.
Gasoline tax information - Connecticut Gas Prices
Edit: The table is total US fuel tax by state, so Federal taxes are in there, but not broken out it appears.
   / Diesel confirmed in new Chevy Colorado. #178
...we pay 75 eurocents per liter on gas, 45 on diesel, then another 21% VAT... :p
Don't worry, with the progressives running things here (for now), we're catching up real fast. :thumbdown:
Haven't visited the post I started in a while. I've been working 10+ hour days at the plant and worked this past Saturday also. We have been building 2 pilot trucks a day and must say the finished product looks beefy and bold for a small truck. Body fit and paint finish is exceptional for this early in the build process. We have a black Z-71 extended cab on display in the plant equipped with the V-6 gasser. Love the ride height. It really does give it a larger appearance. I still don't know a price point yet. I do know that it will be priced comparably w the Tacoma. I'm ready to see sellable units going down the line with all the different colors and options. Just giving everyone a quick update on the progress.
   / Diesel confirmed in new Chevy Colorado. #180
....I'm ready to see sellable units going down the line with all the different colors and options. Just giving everyone a quick update on the progress.
Thanks Topkicker. I like what we've seen and the observations that you've shared. I'm holding out for one with a heavy duty manual transmission. Not getting my hopes up though.
Ford NAA Jubilee Tractor (A52748)
Ford NAA Jubilee...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
5ft 3 Point Hitch Bog Harrow (A51573)
5ft 3 Point Hitch...
