Pallet forks suppose to be loose or SSQA bracket improperly made?
/ Pallet forks suppose to be loose or SSQA bracket improperly made? #21
Oddly enough it is not just PalletForks.com. I bought a Wildkat that was not that good of a fit either. How hard can this be? Not a big deal to weld on a shim, but geez.
/ Pallet forks suppose to be loose or SSQA bracket improperly made? #22
My forks and grapple were from Wildkat. I had to mod both, but I have a welder so it was a simple fix and it was worth it for the price paid.
HP
/ Pallet forks suppose to be loose or SSQA bracket improperly made? #23
If you have a tractor and multiple implements, you really need a welder. I remember not having a welder and it sucked. Heck I used to have a welder to keep an old lawn tractor going. There is just a limit to what you can do with screws, nuts and bolts and gusset plates. And the things pay for themselves, usually pretty quickly.
James K0UA
I have a Miller Maxstar 200 & a little bit of TIG skill, just not that much. I need to keep telling myself to just do it. If the welds break I can just redo it & do a better job next time.
/ Pallet forks suppose to be loose or SSQA bracket improperly made? #25
So if I spend $700 on a implement I should buy a welder too so I can use it. Sorry I don't see it that way. If you make something to sell and to do a job it should do it. If you bought a tractor with a implement and you beat the dealer down on price and the implement doesn't work right would you say it was worth it or take back for a new one.
S*%t happens. I'd rather get a defective implement from a good vendor who will stand behind their product & make things right than a company that won't. They have given me good options to either get a few bucks back & fix it myself (of have another welder fix it) or swap out the frame. Probably going to be less hassle for me to fix it myself than to mess with shipping.
Anybody have the specs or blueprints for the SSQA standard? My Googlefu is failing me.
/ Pallet forks suppose to be loose or SSQA bracket improperly made? #29
I am glad it worked out for you.
/ Pallet forks suppose to be loose or SSQA bracket improperly made? #30
I say "make some sparks"... What is the worst that can happen?
/ Pallet forks suppose to be loose or SSQA bracket improperly made? #31
I don't think that is what they are saying. Just that when having a tractor s##t happens and it is a good idea to have one. Pallet forks does stand behind there items. The loose part really isn't a big problem unless you are using the forks for things they weren't made for. Mine are loose also but that is it and for lifting straight up like they were made for it isn't a problem, I also have a pallet fork grapple and I haven't noticed if it is loose or not, I have a welder and can repair if needed because I'm just an old farmer at heart.
/ Pallet forks suppose to be loose or SSQA bracket improperly made? #32
We had a neighbor like that. If he saw anything amiss on a piece of machinery the first thing he wanted to do was fix it. Picture a man in overalls, with wrench, pliers, and screwdriver in his pocket at ALL times!. If you even remotely complained about anything mechanical/electrical etc. he would say "well lets take a look at that!" The man could repair or fabricate anything you could imagine. The world needs more people like him in my opinion.:thumbsup:
James K0UA
/ Pallet forks suppose to be loose or SSQA bracket improperly made? #33
James K0UA
I know a guy that's 89 and he's like that. 5 years ago he built his own 6' brush cutter because he just couldn't find one he liked. :thumbsup::D
Know that guy too... My brother's father in law. Learned a lot from him. As opposed to my neighbor/mentor who was more the over-engineering do it perfectly type.
I really need to work on my Get Er Done jury rigging skills rather than trying to precision over-engineer everything. Not that big of a deal to go it good enough when you can just weld it back up when it brakes again.
Picked up some 1/4" x 3/4" stock today.
/ Pallet forks suppose to be loose or SSQA bracket improperly made? #35
I highly doubt anything will break, there is not going to be much stress on the weld. Mainly with forks it is just going to keep them from bouncing around when not loaded and you are in motion with the tractor. The force on a set of forks is downward on the top edge of the SSQA, the keeper pins don't come into play unless you are uncurling and/or pulling backwards, not something you do with forks.
/ Pallet forks suppose to be loose or SSQA bracket improperly made? #36
Well stated Tom. I think that's also why manufacturers don't worry too much about a snug fit with their QA setup. As someone said earlier, you can't have that looseness with a Grapple/bucket or you risk tearing something up.
/ Pallet forks suppose to be loose or SSQA bracket improperly made? #37
James K0UA
My dad was like that. We had a big pile of scrap metal outside the shop on our farm. When anything broke or needed some "southern engineering", he'd go dig in the scrap pile and find something and then we would fire up the cutting torch and the welder.
He could fix anything or rig up anything to work. Unfortunately, I didn't inherit that gene from him.
/ Pallet forks suppose to be loose or SSQA bracket improperly made? #38
I bought my grapple from Palletforks.com as well, and yes I had a loose fit too. I simply welded a couple pieces if flat stock stock across the back of the holes, and corrected the issue. I did call palletfoks and let them know of the problem, and they immediately shipped me a set of the mount plates. They were actually duplicates of the original 1/4 inch mounting plates, (to double up the thickness). I was pleased they handled this for me. I have to admit, I have yet to grind off my fix, and weld the new plates!
/ Pallet forks suppose to be loose or SSQA bracket improperly made? #39
I agree with the members who say 'just git er done'. I guarantee you'll spend more time admiring your fix than you spent fixing it. Have fun !
Terry
/ Pallet forks suppose to be loose or SSQA bracket improperly made? #40
Terry
Yep, my welds with my old Lincoln 225 were all goobered up, but it worked! Ended up buying me a Miller Mig machine.
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2017 Ford F-550 Service Truck (A59230)
2017 Ford F-550...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A59230)
2011 Peterbilt 365...
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
