Rock salt on my concrete driveway
   / Rock salt on my concrete driveway #1
jinman
Rest in Peace
Texas - Wise County - Sunset
NHTC45D, NH LB75B, Ford Jubilee
Oh boy! With the early December ice storm, I used rock salt to melt a walking path down my driveway. Now, the surface is all pocked and chips are coming up. I am shocked to see online info that salt and concrete don't mix if the concrete is not finished with the right compound. Live and learn, I guess. My damage isn't too bad, but I sure won't do this again. Next time I'll use just sand on top of the ice. I've learned my lesson the hard way.:rolleyes:
   / Rock salt on my concrete driveway #4
Pressure wash walk a.s.a.p. scuff surface good than hose off,maybe skim coat of cement might work.
We only use rock salt on tar and keep away from plants also trees.
   / Rock salt on my concrete driveway #5
I used to plow snow at a shoping center with a concrete parking structure and the owner did not allow salt on it. We used Urea fertilizer (0-0-64). It's nitrogen. Buying a ton of that in the winter might got you a visit by the gubment these days. This was many years ago, and you'll have some mighty green grass around your walkway in springtime!
   / Rock salt on my concrete driveway #6
Did I not tell you sand or stone grit is your friend? :D
I didn't know that about concrete types either. Makes sense though when concrete floors in garages can get pocked by dripping salt slush.
Sand also has the advantage of staying on top of the ice where it does some good. The ice melt stuff melts a BB-sized hole down into the ice and leaves the surface slippery.
   / Rock salt on my concrete driveway #7
Whoever did the concrete should have sealed it. I know this, because we had new pre-cast concrete steps installed on our front porch. The following spring, I noticed the step were ruined. Why? Because I used ice melter on them. I called the company that installed them and they told me I should have sealed it. I told them that perhaps, when selling and installing these things, they might want to let ignorant home owners such as myself know that concrete has to be sealed. They said all contractors know that.... I reminded them that they were the contractor. Grrrr. Short answer.... tough peanuts. Not their fault. Grrrrr.....
   / Rock salt on my concrete driveway #8
Using fertilizer to melt the ice can mess up the concrete as well. At our city house, melting ice/snow would fall on the concrete driveway and walkway and refreeze. We would never have salt to remove ice since we don't often have this problem but I would use whatever fertilizer we had on hand which would eat up the top layer of concrete.
Later,
Dan
I just took a couple of photos of the worst spots on my driveway. These are both about 3'x3'. I won't be doin' anymore salt here. I can use it on my deck and steps, but not on the concrete.
   / Rock salt on my concrete driveway #10
That's unfortunate Jim. I think someone told me that the salt makes hydrochloric acid with the water and dissolves the cement in the concrete. Anything that makes an acidic mixture will have the same effect.
I'm sure not disputing what you say, but I can mix salt and water all day that never becomes HCl. My mouthwash is a mixture of salt, water, and baking soda. It is suggested as a non-acidic mouthwash for people prone to acid sores. My wife thinks the damage occurred when the ice refroze. Her theory is the salt allowed the water to soak into the surface of the concrete and then refreezing popped these little discs of surface concrete up. I don't really see dissolved concrete as you'd normally see with HCl. I'm inclined to agree with my wife's theory because it fits so well with what I'm seeing. It doesn't matter really. I now know not to do it anymore.:eek:
   / Rock salt on my concrete driveway #12
I was told years ago that if the concrete finish is worked up good with a wood float before troweling, it would tolerate salt in the winter better than just using a magnesium trowel. They say it works the aggregate further down and leaving a little more gravy on top for a little more protection.
Has anyone in the business an opinion about this?
   / Rock salt on my concrete driveway #13
View attachment 352215View attachment 352216[ If you do just the deck and steps leave a mat before the driveway or your shoes will carry the salt on your concrete. If you don't wipe your feet you will leave foot print marks on the concrete.
   / Rock salt on my concrete driveway #14
I started a thread on this a while back--search for it--and what I recall was that a higher PSI mix was less likely to pit and a lower PSI mix more likely to pit. Sealers helped but I don't think that was the final answer. I really sealed mine good and put no salt on it and hope I can stop or at least slow down the process..
   / Rock salt on my concrete driveway #15
My wife thinks the damage occurred when the ice refroze. Her theory is the salt allowed the water to soak into the surface of the concrete and then refreezing popped these little discs of surface concrete up. .:eek:
This is what I have heard actually causes it to "spall". Not sure if exactly as she said, but the re freezing part was in the explanation.
   / Rock salt on my concrete driveway #16
I worked in concrete coating business for several years , from my experience it is a combination of a poor quality finish and cheap concrete made visible sooner by the application of salt.
You might as well use salt because the whole surface will do it eventually. A good commercial sealer would greatly slow the process. Google Sure Crete, they have a very high quality outdoor sealer that is very effective.
My driveway has been in for 12 years with no other issues. It may not be the best, but is has been trouble free. We really have mostly mild winters and this is the first time I've ever applied salt. I will Google Sure-Crete and see if it is carried locally at Lowes or HD. Thanks for the tip.
   / Rock salt on my concrete driveway #18
I apologize if what I said offended you. Spalling is typical of concrete that has had to much water added, overworked in the finishing process ,or just didn't have enough cement in the mix to start with. The sealer , whatever brand you may use , should be a penetrating type.
It will actually do more as a binder than a sealer in that respect to keep the rest of the spalling at bay.
   / Rock salt on my concrete driveway #19
From what I have seen..... if you keep the ice/snow wet you won't have spalling problems.
I use a chemical that keeps water wet to about -10 so I am good here in Maryland. If you melt the snow the water goes into the concrete. If it freezes it can pop. Don't let it freeze.
If skim coating won't fix it there is a product called Roklin that will.
No apology needed or expected. I was just trying to show why I was so surprised to see the damage. My concrete contractor was less than ideal. Many contractors are sloppy out in the country in Texas where no inspection is required. If you are not there, they cover up rather than fix mistakes. In one instance, this contractor poured over 9 yards of concrete for back-fill in an area that should have been formed and back-filled with dirt.
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2349 (A60432)
2349 (A60432)
7021 (A55851)
7021 (A55851)
2018 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2018 CATERPILLAR...
2020 BOBCAT MT55 STAND-ON SKID STEER (A60429)
2020 BOBCAT MT55...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
