Made a shooting range
   / Made a shooting range #22
Some times I have a male doctor, some times he is busy, and I
must see a female doctor.
But, I'm sure you could not figure that simple thing out.
Should I put him/her??????????
See, you can't even use proper quotation tagsLOLOLOLOL
It should then be: '...if you like your doctors...'
I already quoted you; the single quotes are due to paraphrasing your statement, to which you give no credit to who's statement it was in the first place.
Multiple ? marks doesn't show any more emphasis, just a high level of no knowledge of punctuation.
When it comes to figuring out simple things, granted you are king.
   / Made a shooting range #23
holy cra* batman...where has this post gone to
   / Made a shooting range #25
I spend a lot of time at many different ranges, and while the OP's backstop is small, for someone who is very careful, and is doing something limited like sighting in a rifle a couple of times a year, it would be okay.
I'm going to be building three different backstops on my property this year. The main one is going to be a 50yd range behind my barn. The plan is to stack 2x2x8' concrete blocks five high (considering six), and six wide across the back. Then I'll add more blocks on each side of the backstop to create side berms, again five (maybe six) high, but only three deep. This will give me a U-shape backstop that is 48' wide, with 24' long side berms, and then I'll backfill with dirt in front of the blocks. The area behind, and on both sides, of this is heavily treed, with no houses within at least a quarter of a mile (only one or two, with the rest being more like half a mile).
The second backstop will be my 200yd range. It is essentially a 30ft wide cut through the trees, and I'm going to build a wall with railroad ties, and telephone poles that's probably 8x8', then backfill in front with dirt. The area behind that is extremely heavily treed, and there's virtually no way I'm missing an 8x8' backstop doing the kind of shooting I do.
The third backstop is going to be a 25yd range that I only use as a backstop for accuracy (off a bench/Ransom rest) and chronograph testing. I plan to make it similar to the 200yd backstop, but it's going to be set up so that I can shoot to it from one of my barn doors. I'm going to put it in a different direction than the 50yd range, because I want to have the best sunlight possible when doing accuracy test...which means I need two different directions for different times of day. Again, I'm not going to miss an 8x8' backstop doing bench accuracy, or chronograph work, so I'm not worried about the height, and it will have heavy trees behind it.
So, one range for "dynamic" shooting (I'm a USPSA shooter for folks who are familiar), and two backstops for static, deliberate shooting.
   / Made a shooting range #27
I like they setup you have for holding up the targets. Very clever.
ya..nice and cheap. but my wife went to town on the middle one with my Saiga 12 and ill have to do some rebuilding in the springtime....that should cost me about $2.00 and 4 screws hehe
i use a hand stapler to hold the targets. quick and easy
   / Made a shooting range #28
Here's mine............
   / Made a shooting range #29
Took me 2 plus years to build in my spare time................
   / Made a shooting range #30
I recently had to add a center support because of 30 plus inches of snow on the roof............Total width is 16 plus feet wide and 8 plus feet deep.........7 or so feet tall in the front and filled with dirt..............
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2025 JOHN DEERE X350 LOT IDENTIFIER 153 (A53084)
2025 JOHN DEERE...
2019 KUBOTA U35-4 EXCAVATOR (A51246)
2019 KUBOTA U35-4...
2021 John Deere 331G Track Loader (A53342)
2021 John Deere...
2010 Ford Crown Victoria (A51694)
2010 Ford Crown...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
