Gas in a Diesel engine
   / Gas in a Diesel engine #1
chrisdvorak
Gold Member
RI
too many
I just purchased a trojan 164a wheel loader. It's an old machine with a 2 cycle Detroit Diesel engine in it. Anyway after I got it home and unloaded it I opened the fuel cap and smelled gas? The machine ran fine the whole time I got it off the trailer and parked it until I shut it off! My question is would I be causing any damage to the engine by just running the rest of the gas out and refilling with diesel?
- thanks
   / Gas in a Diesel engine #2
Unless it is a military multi-fuel engine it could be permanently damaged by running gasoline in it. You could have been running on fuel from the filters to the pump and some one could have filled the tank with gasoline by mistake. I would not run it anymore until I drained the entire fuel system and purged the lines all the way to the pump with fresh diesel.
   / Gas in a Diesel engine #3
yeah I would drain it and add some fresh #2... Might even throw a couple bottles of 2 cycle engine oil in it.
Should the 2 cycle engine oil replace my regular fuel additive or just add to it? Should I always add it to the fuel of this loader or just the first tank after I get the gas out? I appreciate the info as this is the first 2 stroke diesel I have owned.
   / Gas in a Diesel engine #6
Drain the tank! I poured gas in my diesel tractor by mistake, it would barely run. I would change the engine oil once it was running on the correct fuel.
   / Gas in a Diesel engine #7
BIG reminder here ----- when changing oil in a two stroke Detroit ONLY use the required engine oil. This is always a straight weight diesel 30 weight or 40 weight.
If 15w40 is used, you could run the risk of engine damage upon start up in minutes!! At start up with the cold oil thickness is 15 weight, upon running for a few minutes or longer it warms up to 40 weight. At this point the engine can be damaged very fast. Please remember and please pass along the info!
   / Gas in a Diesel engine #8
Drain it ASAP and put fresh diesel and filters on it.
Chris
   / Gas in a Diesel engine #9
That isn't how oil viscosity works.
   / Gas in a Diesel engine #10
I agree with PoorMansCat. Drain the fuel tank and replace with clean Diesel and some Diesel fuel conditioner. Detroit recommends SAE40 year round. That means, where you are, a block heater would help with the starting. I doubt you hurt the engine by running it. Those "Driptroits" would put up with about anything but lugging. Wind it right out and run it like you just hit your hand with a hammer, it will be a much happier engine that way.
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
Magnum 125 Generator (A53421)
Magnum 125...
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
377789 (A51573)
377789 (A51573)
Livestock Hay Ring - Round Bale Feeder (A55218)
Livestock Hay Ring...
