Best rear tire filler for cold weather
   / Best rear tire filler for cold weather #21
you put air and fluid in a tire the exact same way. thru the valve stem ;)
   / Best rear tire filler for cold weather #22
I know that but how do you get the water into the valve stem ,, sorry never done that?
   / Best rear tire filler for cold weather #23
jack that tire up, remove core.. deflate tire.
pump or garvity feed ballast liquid into tire using a piece of rubber line pushed over the valve stem. 5/16 maybee.. whatever fits your stem. then a pump. drill pump.. etc..
use a burp valve.
many people put in a concentrat like ww fluid or af first. then add water. the ballast can go in without the burp valve usually.. then hookup a water hose ( garden hose ).. and fill it hitting the burp button now and then.
when you have fluid over the top of the top of the rim, remove hose and slap valve core in. then air tire up to propper pressure.
obviously start with stem at top.. etc.
if you are tubeless and tire comes off bead/rim at deflate. you have a problem. which is why I like tubes....
   / Best rear tire filler for cold weather #24
ps. napa and tractor supply and probably most farm stores have the burp valve that goes from hose thread to valve stem thread ( with a couple different size adapters to cover most common stem types. )
   / Best rear tire filler for cold weather #26
have fun!
in florida I use safe antifreeze and just add enough to prevent a solid freeze.. slushy is fine.. which is a pretty thin mix for florida.. then I hose it the rest with h20..
cheap weight
   / Best rear tire filler for cold weather #27
To the OP,
Is the fluid actually freezing or is just the tires are flat spotted from the cold. Some brands of tires are much worse than others for doing this.
   / Best rear tire filler for cold weather #28
   / Best rear tire filler for cold weather #29
Study it out before you try it. I jacked the tractor off the ground a couple inches and as soon as I let the air out the bead popped loose and Rimguard started dumping all over. Then you have a problem. I understand that if the tire is jacked up but still resting slightly on the ground it should be alright. Just food for thought.
   / Best rear tire filler for cold weather #30
This works very well in my experience. ;)
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A51247)
UNUSED CFG...
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
(APPROX 15) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 15) 2" X...
