JD 3320 will not move after calibrating throttle sensor
   / JD 3320 will not move after calibrating throttle sensor #21
same problem here, the tractor starts but won't move. should I fix the error 08 before calibrating?
   / JD 3320 will not move after calibrating throttle sensor #22
It would seem to make most sense to fix the error code first, then calibrate based on everything stated to date in this thread.
   / JD 3320 will not move after calibrating throttle sensor #23
I adjusted the throttle sensor within specs, the front and rear pedals to specs. but the pedal high specs were higher than the book. So I put a deep socket between the pedal and the floor so the pedal would not bottom out. I went into the calibration mode and followed the procedure and DONE. It works now, moves forward and backwards. Giddy up!
   / JD 3320 will not move after calibrating throttle sensor #24
Would this be of any help? F&R pedal sensor adj 1.pngDrive pedal  adjustment 2.png
   / JD 3320 will not move after calibrating throttle sensor #25
sure. I used the onboard diagnostic mode #2 for e-hydro. my manual might be newer than yours, the writing and page #s are different.
   / JD 3320 will not move after calibrating throttle sensor #26
Great! For clarification, did you fix the error code 1st, or do the calibration/socket adjustment and in the process fix the error code at the same time?
   / JD 3320 will not move after calibrating throttle sensor #27
yes I did, if you don't the tractor won't calibrate.
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A55852)
2005 Toyota Tundra...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
Super Star Smithco Bunker Rake (A50324)
Super Star Smithco...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A55301)
2020 Massey...
378813 (A51573)
378813 (A51573)
