JD 3320 will not move after calibrating throttle sensor
   / JD 3320 will not move after calibrating throttle sensor #21
same problem here, the tractor starts but won't move. should I fix the error 08 before calibrating?
   / JD 3320 will not move after calibrating throttle sensor #22
It would seem to make most sense to fix the error code first, then calibrate based on everything stated to date in this thread.
   / JD 3320 will not move after calibrating throttle sensor #23
I adjusted the throttle sensor within specs, the front and rear pedals to specs. but the pedal high specs were higher than the book. So I put a deep socket between the pedal and the floor so the pedal would not bottom out. I went into the calibration mode and followed the procedure and DONE. It works now, moves forward and backwards. Giddy up!
   / JD 3320 will not move after calibrating throttle sensor #24
Would this be of any help? F&R pedal sensor adj 1.pngDrive pedal  adjustment 2.png
   / JD 3320 will not move after calibrating throttle sensor #25
sure. I used the onboard diagnostic mode #2 for e-hydro. my manual might be newer than yours, the writing and page #s are different.
   / JD 3320 will not move after calibrating throttle sensor #26
Great! For clarification, did you fix the error code 1st, or do the calibration/socket adjustment and in the process fix the error code at the same time?
   / JD 3320 will not move after calibrating throttle sensor #27
yes I did, if you don't the tractor won't calibrate.
2018 MGB 2500HP QUINTUPLEX FRAC PUMP (A55745)
2018 MGB 2500HP...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
John Deere 1025R (A53317)
John Deere 1025R...
2017 Green Thumb 58OSN3 8ft Pressure Washer Trailer (A55787)
2017 Green Thumb...
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
