Looking at old grain trucks... Need help.
   / Looking at old grain trucks... Need help. #31
It will be a new experience driving the two speed axle. You might become familiar with double clutching.
   / Looking at old grain trucks... Need help. #32
Which ever one u buy you'll love it .. Can't beat having an old grain truck on the farm ... Here's one I got a few months back .. 59 International
   / Looking at old grain trucks... Need help. #34
Only if the transmissions are not synchronized, right? The only ten speeds I've driven were synced, but they were from the 70s. If the 2speed is unsynchronized, I'd bet the single is too. It's not hard to double clutch at all, and if they are unsynchronized, you can "float" the gears, or shift without the clutch. That seems to be the method of choice for the big rigs.
   / Looking at old grain trucks... Need help. #35
55 0r 56 Dodge?
If your asking me .. The picture is of my 59 international ... That baby is fine ... Lost brakes this week appears to be the booster under the drivers side on the frame ... So I'm searching a rebuilt kit or a rebuilt unit .. That's a down fall when u own own that age
   / Looking at old grain trucks... Need help. #36
That always a fun ride when you push on the pedal and it pushes back or nothing there. In my youth (10 years ago) I ran my loadstar to and from work for a few days with no brakes waiting on a hydravac. Truck had a taste for them.
My dad worked for a dairy farm in western New York years ago. He was driving their old grain truck and lost the brakes on a run. Sailed right through an intersection. Luckily, no traffic and no ditch on the other side. He was able to coast it to a stop once he got past. You can bet some brake lines got replaced in a hurry!
Joe
   / Looking at old grain trucks... Need help. #38
Whoo; did I goof.
   / Looking at old grain trucks... Need help. #39
IF you have a good ear and a tack that works, then you can shift without the clutch. Myself, I would use the double clutch method until I got real familiar with the truck long before I would try shifting without. A little background for you, I have 50 years of trucking under my butt and most of it I shifted without the clutch AFTER I got familiar with the trannys.
   / Looking at old grain trucks... Need help. #40
Oh yeah, I forgot that a truck like that would probably not have a tachometer. Having the tach really helps the learning curve for shifting without a clutch. I suppose you could install one. If the tranny is unsynchronized, you'd want one either way, right double clutching or floating?
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2012 Club Car Carryall 1 Utility Cart (A55851)
2012 Club Car...
2017 Bobcat T770 Compact Track Loader (A55314)
2017 Bobcat T770...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
1992 Ford LT9000 T/A Day Cab Truck Tractor (A55852)
1992 Ford LT9000...
