LouieJunior
I could always use more horsepower but it works well. I have 32 HP @PTO. I rigged up a flow control valve for the lateral movement which slows it down and helps prevent stalling. Each stump takes a bit longer, but it reduces wear and tear on the gearbox and the teeth too.
I'd like a bigger tractor someday, but right now I need to trailer it back and forth between two properties and my weight constraint is 5K pounds, with FEL @ 3-point attachment.
