Anyone Use a 3pt Stump Grinder?
   / Anyone Use a 3pt Stump Grinder? #1
GaryBDavis
Gold Member
Andice, Texas
I've got a chance to pick up a lightly used Baumalight 3pt stump grinder for about $2500. This model with a 24" disc sells for ~$5600 new. I've got enough HP and hydraulics to run it.
A stand alone stump grinder with a 65HP engine behind it does a heck of a job. I'm wondering if I will get similar results with this one. I have several large hardwood stumps I need to grind down. Then I'll probably sell it in a year or two and try and recoop most of my money.
Anyone have any experience with one of these types of stump grinders?
   / Anyone Use a 3pt Stump Grinder? #2
I'm gonna suggest using the search function using "stump grinder" for a little reading. There are only a few members on TBN with PTO stump grinders....... according to past threads on them. The cheapest I've ever seen a PTO stump grinder for sale in these parts was $2000 (in unknown condition), so I'd say your price is very good. Heck...... if you were closer I might offer to buy it from you when you were done!. The Baumalights look at be well made, and probably the brand I'd look to buy if I were shopping for a new one. Just a guess, but I suspect you'll be content with the results of a PTO grinder..... things just aren't going to happen as fast as with the stand alone unit you had for comparison.
   / Anyone Use a 3pt Stump Grinder? #3
Gary,
I bought a Woods model TSG50 for my Kioti DK45S a year and a half ago. Paid $3100 brand new from a local dealer. I bought it to add a extra service to my land maitenence business. It does a good job and was well worth the investment. Woods also makes a larger version for 50hp pto and up model SG100. Hope this helps.
Well, I picked the grinder up for $2,000. I've ground down about 30 to 40 stumps so far and it's working like a charm. Pretty sweet alright. I wouldn't won't a cheap one or I'm sure I'd tear it up. The largest one was about 28" in diameter and about 1 foot above the ground.
   / Anyone Use a 3pt Stump Grinder? #5
Congrats on the purchase! It looks to be in nearly new condition from what I can see. It is made very similar to the Woods TSG50 that I have.
   / Anyone Use a 3pt Stump Grinder? #6
Gary, let me know when you are done with it !! ;)
That looks nice....... you did good !:)
   / Anyone Use a 3pt Stump Grinder? #7
I am using a Woods TGS50( like new condition) and have did 40 hardwood stumps and have about that many to go. Has done a great job to this point, not as fast as a stand alone unit. I will(if rain ever stops) be done by Sep and putting mine up for sale for $2700.
   / Anyone Use a 3pt Stump Grinder? #8
They sure do work well! I have the Shaver SC-50 which is the same as the Woods TSG-100, I don't think I'll ever sell it!
(Not sure if you realize but this thread is from 2009, doesn't matter though, it's always nice to see more pics of stump grinders)
   / Anyone Use a 3pt Stump Grinder? #9
I also have a Shaver -- Model S25, new last year. Works great. I will never run out of stumps to grind :(
   / Anyone Use a 3pt Stump Grinder? #10
Louie,
How does your tractor do with the SC25? Does it bog down much running it? I'm at the bare minimum amount of hp for the SC50. If I was buying new I would have wound up purchasing the 25 as it would be a better fit for my tractor, however, I came across a deal I couldn't refuse so I picked up the 50. I imagine myself hanging on to the stumpgrinder for probably the rest of my life, since I see no point in selling it. Most likely I'll have a more powerful tractor over the next few yrs or so, and then I'll be able to use the stump grinder to it's potential. As of now, I have to take pretty small bites. It is a lot for my little tractor to handle, but it does handle it.
   / Anyone Use a 3pt Stump Grinder? #11
I could always use more horsepower but it works well. I have 32 HP @PTO. I rigged up a flow control valve for the lateral movement which slows it down and helps prevent stalling. Each stump takes a bit longer, but it reduces wear and tear on the gearbox and the teeth too.
I'd like a bigger tractor someday, but right now I need to trailer it back and forth between two properties and my weight constraint is 5K pounds, with FEL @ 3-point attachment.
   / Anyone Use a 3pt Stump Grinder? #12
I need to install some flow restrictors as well, mine is pretty difficult to feather because of the hydraulic flow at full rpm speed.
   / Anyone Use a 3pt Stump Grinder? #13
I'm Interested if you want to sell it.
Mark
   / Anyone Use a 3pt Stump Grinder? #14
If anyone has a 3 point grinder for sale, I'm very interested.
Thanks, Mark
   / Anyone Use a 3pt Stump Grinder? #15
Very Interested but I don't see a price.
We even have our own film crew and we blog post our equipment.
Thanks Mark
   / Anyone Use a 3pt Stump Grinder? #16
Thanks Mark
Price for what?
   / Anyone Use a 3pt Stump Grinder? #17
A post was removed -- from Baumalight with a link to their grinders
Baumalight has just replied to a thread you have subscribed to entitled - Anyone Use a 3pt Stump Grinder? - in the Attachments forum of TractorByNet.com.
   / Anyone Use a 3pt Stump Grinder? #18
3 point stump grinder for 36hp tractor
   / Anyone Use a 3pt Stump Grinder? #19
Ohhh Okay, that makes sense...
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
Bobcat 873 (A55272)
Bobcat 873 (A55272)
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2018 CATERPILLAR...
Forklift (A56857)
Forklift (A56857)
UNKNOWN 500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
