Ram1500 EcoDiesel V6 revealed!
   / Ram1500 EcoDiesel V6 revealed! #561
Think it shows the mall-cruiserifacation of the pick up truck. 1/2 ton class machines are now toys for rich Doctors and soccer moms. Designed for ride quality over toughness and capacity.
490 lbs.. couldnt even carry a 4 wheeler! What a joke.
   / Ram1500 EcoDiesel V6 revealed! #562
Specify the equivalent trucks for the test and the RAM would be right there for payload. Why RAM sent a fully loaded truck that weighs 1100 lbs more than it's nearest competitor is the question. And how exactly do they find 1100 lbs of options to put on the **** thing. Craziness.
   / Ram1500 EcoDiesel V6 revealed! #563
What would be equivalent? A loaded-up half-ton Ford or Chevy? Or Titan or Tundra for that matter? Seriously, 490 lbs of payload in a half ton pickup is like **** on a boar!
   / Ram1500 EcoDiesel V6 revealed! #564
You load any of the brands up like the RAM in the article and you drive the payload down, unless you buy the Ford with the payload package.
   / Ram1500 EcoDiesel V6 revealed! #565
Sure you will drive the payload down, that's a fact of life. But the numbers are not going to be near as low as the Ram.
   / Ram1500 EcoDiesel V6 revealed! #566
If RAM supplied the equivalent truck to the two GM's in the test, it would have a 1600 ~ 1700 lb payload. Again, why RAM sends these mall cruisers to these comparison tests is a mystery.
   / Ram1500 EcoDiesel V6 revealed! #567
This, folks, is the real issue with the Ram EcoDiesel: 2014 Annual Physical: Braking - PickupTrucks.com Special Reports
490 lbs! I'm not big in the 'my numbers are bigger than yours, so my truck is better' game, but this is ridiculous. How are you supposed to tow the 8k lbs if you only have room for < 300 lbs of tongue weight after putting yourself and the hitch in your truck? Granted, it's a fully-loaded version, but still!
Somebody already predicted this problem real early in this thread. Oh Yeah, It was me! I took a lot of heat from this too.
My Post: Number 20 from 7-4-13
Unfortunately the reasons you mention a diesel making sense doesn't apply to the Ram 1500. Payload numbers are poor for this vehicle compared to the competition. Most are rolling off the line around 1000 lbs from what I have seen.
Fuel saving is about the only advantage I see with this offering. Taking advantage of the diesels beautiful torque curve will not be utilized with the low payload capacities.
   / Ram1500 EcoDiesel V6 revealed! #568
Well, why don't we all navigate over to the RAM site and build a 2WD SLT Extended Cab RAM, and see what payload number pops up.
   / Ram1500 EcoDiesel V6 revealed! #569
What does that have to do with the question at hand? The point is, the Ram has less payload than comparable trucks. Period. Load up an F150 or Silverado and see where the payload falls compared to the < 500 for the Ram. In fact, it has less payload that Nissan, Toyota, and Honda mid-sizers in crew cab trim!
   / Ram1500 EcoDiesel V6 revealed! #570
What is on the site is often different than what the door sticker will say the finished product is.
2015 PETERBILT 367 SLEEPER (A52576)
2015 PETERBILT 367...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
Ford Tractor (A50120)
Kubota ZG327 (A50120)
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
