MF 1700 Series Compacts Tractors
   / MF 1700 Series Compacts Tractors #41
FYI - I just spoke with Agco & Holmes Murphy regarding the insurance. They base it off a percentage of the purchase price. For example, on a purchase of around $31,500, the quoted me about $10/mo which covers practically anything you break (not maintenance or mechanical problems) ... but the caveat is a $500 deductible! Ouch. Can't imagine many things costing more than $500, even a glass door!
I wonder how much commercial insurance is?
Too bad USAA doesn't offer commercial coverage as I'll need to head off of the reservation to get coverage. Anybody have any tips to share on getting commercial insurance?
Also, does anybody know if the front loader and 3 point offer a float option?
MO MF Dealer. Thanks for the video presentation. I just read thru this thread,lots of great information.Will you be at the Western Farm Show this next weekend? I so will you have a 1700 series there? lt190b
We hauled a 1736 Hydro Platform, 1759 Cab Power Shuttle and 6616 with CVT into the show today. But will not be able to make the show due to prior commitments. But there will be many AGCO Employees manning the lot and can help answer your questions. Western Farm Show is a non-selling show for the major manufacturers. Best to work with your local dealer and we would be happy to help if you decide Massey Ferguson is right for you.
   / MF 1700 Series Compacts Tractors #44
MO MF Dealer. Thanks for the farm show tip. I spent some time yesterday on the MF site in a chat exchange trying to find out if the subframe mount front blade for the 1600 series tractors will fit on the 1700 series tractors. Would you have an answer? lt190b
   / MF 1700 Series Compacts Tractors #45
Loader has float. 3 Point hitch does not float.
Thanks, MO MF Dealer. Anyway to add float to the three point? I plan to purchase the cab on version and was hoping that dialing out draft allowed the three point to float.
The Prices Pages for the 1405, 1545, and 1550 Front Dozer Blades show compatible in the February 2014 Price Book. They do require an extra bracket kit to convert to the new 1700 Premium Series COmpacts.
Need heard of a tractor, in our 62 Years, with 3 Point with Float Position.
   / MF 1700 Series Compacts Tractors #48
Perhaps I've got my terminology wrong: I want the ability to be able to mount a snowblower on the three point that can follow uneven driveways and such.
   / MF 1700 Series Compacts Tractors #49
That's called draft control. It's an option on the Massey units, it does come standard on some of the other brands, like LS, Kioti, TYM...etc
   / MF 1700 Series Compacts Tractors #50
MO MF Dealer Thanks. Is the subframe and extra bracket kit available without buying the blade? lt190b
If you want to follow the contour with an implement like snow blower the standard 3 point hitch only lifts the implement (No down pressure) so it will "float" along the surface just like a box blade or blade will follow the contour because there is no down pressure. Some three points offer a slotted lift links that allow more movement.
Draft Control is more for ground engaging implements and when over load it will raise the implement thru the tough area and then lower when it senses the load lighten.
I have not tried ordering the attachment kit yet so I cannot tell you 100% of availability in-stock at this time but if I was a betting man they are probably in-stock or available very soon.
Subframes for 1405:
7092102M Subframe for MF1528H and 1531H List $1,778.00
7092103M Subframe Front Quick Hitch List $1,889.00
For all MF1529, 1532, 1533, 1540, 1635 and 1736 Tractors
MF1736 Requires Additional Adaptor Bracket Kit 72530362M. (See Bulletin MF13-36PMB)
72530245M Subframe Quick Hitch for MF1526 List $1,227.00
72530362M Bracket Kit to Convert 7092103M Subframe to MF1736 List $449.00
Subframes for 1545:
7581101M Subframe for MF1547, 1552, 1643, 1648, 1652, 1742, 1749, 1754, and 1758 Tractors List $2,029.00
(All MF1700 Series Models Require Adaptor Bracket Kit 72530363M)
72530363M Bracket Kit to Convert 7581101M Subframe to MF1742, 1749, 1754, and 1758 List $379.00
Subframes for 1550:
(All 1700 Series Models Require Adaptor Bracket Kit 72530363M)
   / MF 1700 Series Compacts Tractors #53
Subframes for 1405:
Subframes for 1545:
Subframes for 1550:
MO MF Dealer. Thank you for the detailed reply.I think this is what I needed. Thanks again. lt190b
   / MF 1700 Series Compacts Tractors #54
Thank you for enlightening me. I clearly misunderstood what somebody had shared with me as I thought draft control was for adjusting the depth level of a three point but when off, it would allow float.
   / MF 1700 Series Compacts Tractors #55
Does anybody know what the Massey part numbers are for 2nd and third hydraulics for the 3 point hitch as well as the Massey kit part number for adding a true 3rd function to the loader?
What model of tractor are you looking for these items for?
   / MF 1700 Series Compacts Tractors #58
MO MF dealer. Do you think a 4610 could safely pull a 15 foot batwing bushhog? TIA
1754 HST or 1758 HST with the DL130 loader.
For 1736 thru 1758 Premium Models Cab or Platform
You need the Lever Kit:
6255416M94 1st Lever Kit Requires one of 6255415M95 (Standard on Cab)
6255417M94 2nd Lever Kit Requires two of 6255415M95
And Valve Kit:
6255415M95 Rear Remote Valve (One Valve Slice) (1st Standard on Cab)
Depends on Material Size but we sell Massey Ferguson and Rhino Rotary Cutters and they recommend from 50 PTO HP (for 1.5" or 2" Diameter Material Capacity) to 70 PTO HP (for 5" Diameter Material Capacity) Batwing 15' Cutters. 4610 is 80 PTO HP so you have plenty of Horsepower.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2011 Toro Workman HD Utility Cart (A59228)
2011 Toro Workman...
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2025 GPS Trailers (A56857)
2025 GPS Trailers...
