MF 1700 Series Compacts Tractors
   / MF 1700 Series Compacts Tractors
Perhaps I've got my terminology wrong: I want the ability to be able to mount a snowblower on the three point that can follow uneven driveways and such.
If you want to follow the contour with an implement like snow blower the standard 3 point hitch only lifts the implement (No down pressure) so it will "float" along the surface just like a box blade or blade will follow the contour because there is no down pressure. Some three points offer a slotted lift links that allow more movement.
Draft Control is more for ground engaging implements and when over load it will raise the implement thru the tough area and then lower when it senses the load lighten.
MO MF Dealer Thanks. Is the subframe and extra bracket kit available without buying the blade? lt190b
I have not tried ordering the attachment kit yet so I cannot tell you 100% of availability in-stock at this time but if I was a betting man they are probably in-stock or available very soon.
Subframes for 1405:
7092102M Subframe for MF1528H and 1531H List $1,778.00
7092103M Subframe Front Quick Hitch List $1,889.00
For all MF1529, 1532, 1533, 1540, 1635 and 1736 Tractors
MF1736 Requires Additional Adaptor Bracket Kit 72530362M. (See Bulletin MF13-36PMB)
72530245M Subframe Quick Hitch for MF1526 List $1,227.00
72530362M Bracket Kit to Convert 7092103M Subframe to MF1736 List $449.00
Subframes for 1545:
7581101M Subframe for MF1547, 1552, 1643, 1648, 1652, 1742, 1749, 1754, and 1758 Tractors List $2,029.00
(All MF1700 Series Models Require Adaptor Bracket Kit 72530363M)
72530363M Bracket Kit to Convert 7581101M Subframe to MF1742, 1749, 1754, and 1758 List $379.00
Subframes for 1550:
(All 1700 Series Models Require Adaptor Bracket Kit 72530363M)
   / MF 1700 Series Compacts Tractors #53
Subframes for 1405:
Subframes for 1545:
Subframes for 1550:
MO MF Dealer. Thank you for the detailed reply.I think this is what I needed. Thanks again. lt190b
   / MF 1700 Series Compacts Tractors #54
Thank you for enlightening me. I clearly misunderstood what somebody had shared with me as I thought draft control was for adjusting the depth level of a three point but when off, it would allow float.
   / MF 1700 Series Compacts Tractors #55
Does anybody know what the Massey part numbers are for 2nd and third hydraulics for the 3 point hitch as well as the Massey kit part number for adding a true 3rd function to the loader?
What model of tractor are you looking for these items for?
   / MF 1700 Series Compacts Tractors #58
MO MF dealer. Do you think a 4610 could safely pull a 15 foot batwing bushhog? TIA
1754 HST or 1758 HST with the DL130 loader.
For 1736 thru 1758 Premium Models Cab or Platform
You need the Lever Kit:
6255416M94 1st Lever Kit Requires one of 6255415M95 (Standard on Cab)
6255417M94 2nd Lever Kit Requires two of 6255415M95
And Valve Kit:
6255415M95 Rear Remote Valve (One Valve Slice) (1st Standard on Cab)
Depends on Material Size but we sell Massey Ferguson and Rhino Rotary Cutters and they recommend from 50 PTO HP (for 1.5" or 2" Diameter Material Capacity) to 70 PTO HP (for 5" Diameter Material Capacity) Batwing 15' Cutters. 4610 is 80 PTO HP so you have plenty of Horsepower.
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
XCMG CV83PD (A53317)
2001 Pierce Spartan Model Tilt Pumper Fire Truck (A59230)
2001 Pierce...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
1453 (A57192)
1453 (A57192)
2021 Deere 333G (A53317)
2021 Deere 333G...
