Ram1500 EcoDiesel V6 revealed!
   / Ram1500 EcoDiesel V6 revealed! #631
It's not that I don't feel comfortable. It's you don't need to push equipment to its limits all the time. The point I'm trying to make is if you are going to tow more than 10,000 lbs more than a few times a year short distance don't do it with a maxed out half ton. Have some safety margin. It's not all about you. You need to make sure you aren't endangering other people on the road to stroke your my half ton is the baddest in the land ego.
From the ram website ram towing guide. RAM 1500
LARAMIE LIMITED
5.7L HEMI® V8 MDS VVT
CREW | 6'4" | AUTO | 4X4
AXLE RATIO
3.92
View/PrintMAX PAYLOAD
1,077lbs
MAX TOWING
9,750lbs
STARTING MSRP*
$51,760
RAM 1500
LARAMIE LIMITED
3.0L V6 TURBO DIESEL
AXLE RATIO
3.92
859lbs
MAX TOWING
8,350lbs
STARTING MSRP*
$54,610
And and SLT pretty loaded option level
RAM 1500
SLT
AXLE RATIO
3.92
1,409lbs
MAX TOWING
10,050lbs
STARTING MSRP*
$40,200
   / Ram1500 EcoDiesel V6 revealed! #632
LARAMIE LIMITED
AXLE RATIO
3.92
1,077lbs
MAX TOWING
9,750lbs
STARTING MSRP*
$51,760
RAM 1500
LARAMIE LIMITED
AXLE RATIO
3.92
859lbs
MAX TOWING
8,350lbs
STARTING MSRP*
$54,610
RAM 1500
SLT
AXLE RATIO
3.92
1,409lbs
MAX TOWING
10,050lbs
STARTING MSRP*
$40,200
Those numbers look pretty low considering the delivered trucks yellow sticker is almost always significantly lower yet.
   / Ram1500 EcoDiesel V6 revealed! #633
Those are even lower than I expected. I wonder if this is why the Ram truck guy jumped ship. Maybe he saw the direction they were headed and wanted no part of it. A true truck design team, engineer, or anyone with a career in trucks would never be in favor of these poor specs.
   / Ram1500 EcoDiesel V6 revealed! #634
I had the same thought about this being the reason Dmace left. I enjoyed going back and forth with him. It was nice to see him back a few weeks ago (new user name) to find out that he was banned from the site. He was also doing a lot of praying that the ecoboost would be a flop and fail miserably.
I want Ram to get this issue addressed and be successful because they have an innovative drive that is greater than the rest.
   / Ram1500 EcoDiesel V6 revealed! #635
You really believe the manufactures have the tow ratings set at the trucks limits? If so this explains everything. I bet they have a 30 to 50% safety margin built in to keep the lawyers away and the warranty claims at a manageable level.
Chris
   / Ram1500 EcoDiesel V6 revealed! #636
That is not who I was talking about :D
Although Dmace was passionate about his views.
I was referring to Fred Diaz who left Ram last year. Ram Truck CEO Moves to Nissan USA - PickupTrucks.com News
   / Ram1500 EcoDiesel V6 revealed! #637
Thats because he knew who would put a proper diesel engine in a 1/2 ton truck with real capabilities.
Remember, Dodge Ram and Nissan were working on a joint venture for trucks prior to Chrysler going bankrupt. Nissan backed out when they went belly up. This is where the Cummins Nissan relationship all started.
My guess is in 5 to 10 years Ram will no longer have a Cummins engine in any of its trucks. Fiat will ruin Ram in the end and Cummins will sell engines to everyone like Nissan, Ford, Toyota, ect.
If it wasn't for Cummins Dodge or Ram or whatever you want to call them would not even be mentioned in the same breath as Ford or GM.
Chris
   / Ram1500 EcoDiesel V6 revealed! #638
Chris
You want to bet your families life and everybody else's family on the road with that theory?
Everything is built to minimum spec to save weight and money. To just make it a few hours and days past warranty if used to spec.
If it's rated for 10,000 lb then it rated for 10,000lbs.
   / Ram1500 EcoDiesel V6 revealed! #639
Chris
I can imagine VM diesel making a V8 version of the 3.0L V6. With 4.0L 360HP to a 5.6L making 400HP . For the pickup truck market. Those engines already exist with that bore,stroke, combustion chamber design in 3,4 and 6 cylinder engines. Doesn't take very much imagination to add a few cylinders.
Maybe the safety nannies in the EPA will being to limit HP in vehicles for "our own good"? They eliminated CO, HC and NOX. Surprise manufactures solved that challenge. The EPA discovered diesel particulates and regulated those too. Alas those pesky engineers solved that problem too. Now the EPA has had to dream up CO2 as a problem to justify their empire. The epa has to find another crisis to regulate.
   / Ram1500 EcoDiesel V6 revealed! #640
You really believe the manufactures have the tow ratings set at the trucks limits? If so this explains everything. I bet they have a 30 to 50% safety margin built in to keep the lawyers away and the warranty claims at a manageable level. Chris
One word for you Explorer. Do you know all the things they did wrong that caused that fiasco.
Air Chipping Hammers (A55851)
Air Chipping...
Year: 2016 Make: Chevrolet Model: Tahoe Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 104,678 (A56859)
Year: 2016 Make...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
PALLET OF (6) BOXES OF SAFETY CHAINS (A57192)
PALLET OF (6)...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
HEAVY DUTY JACK (A54757)
HEAVY DUTY JACK...
