Ram1500 EcoDiesel V6 revealed!
   / Ram1500 EcoDiesel V6 revealed! #651
You reasoning then is if a 1/2 ton weighs 5000# empty it should only pull double it's weight right? Then a 1 ton is limited to 15000# since they weigh 7500# empty. Oh yea, a semi should only tow 30000# since the tractor is about 15000# Sound reasoning. Chris
Hmmm I guess you would think it would all move up equally like that huh. 1 ton trucks has stiffer suspension dual tires as an option for the highest payload and towing and many more things a half ton can't compare to. A semi has how many tires in the ground? Yeah I see you direct correlation to just weight. By your reasoning there should not even be a 3/4 or 1 ton truck the half ton Eco boost can do it all. I had two 1 ton fords back to back have the ball joints go out before 100,00 miles. They were used within there specified limits that ford set. You know what the dealer and the regional rep told me with the back to back failures? That I was working the trucks to hard. I said they have never been past what they are designed to haul or tow. They replied yes but I use the trucks in its upper limits day in and day out and increased failures in that type of use is common. I've had many many more problems from the fords and get the same type of line no matter what it is. I understand if you work equipment hard that stuff can wear out quicker but HD 1 ton trucks should not need ball joints every 100,000 miles. I'm running HD rams now and the only issue I've had is with mine and I caused it. I ran too high of tune on my programmer and was over powering the clutch. I chose to replace the clutch with a performance south bend instead if reducing the power and using the stock clutch. I rambled quite a bit but my point is ford can post numbers all they want about the F150 can tow this and pull that but when you start having issues they'll say yeah it can do that but expect failures if you do.
   / Ram1500 EcoDiesel V6 revealed! #652
Yeah, Dodge can't build a truck and if wasn't for Cummins................ Is that why they were named truck of the year the last 2 years? You guys still don't get it do you? The truck could be rated for a load of 200 lbs or 2000 lbs, people don't care. They will use the thing how ever they feel like it. Look at the thread about people towing or hauling something wrong.
Most of the people on this board are more informed, they are more likely to actually tow something or haul something. Most of America just uses it like a car with a big bed in back.
   / Ram1500 EcoDiesel V6 revealed! #653
I agree Dodge is as capable as Ford or Gm in building trucks.
but it doesn't make a lot of sense to me that they broke the mold on the new Hd 2500-3500 and then (for whatever reason ) stick the 1/2 ton with such pathetic payload ratings, Dodge has to know that this will really hurt their new 1/2 ton sales for people that do compare ratings.
Perspective buyers are going to want competitive ratings on the payload....BEFORE laying down $30k + if this is about ride quality most would give up some ride plushness for more payload, - now if the reason is something else, I hope they deal with it post haste...
   / Ram1500 EcoDiesel V6 revealed! #654
I Maybe the safety nannies in the EPA will being to limit HP in vehicles for "our own good"? They eliminated CO, HC and NOX. Surprise manufactures solved that challenge. The EPA discovered diesel particulates and regulated those too. Alas those pesky engineers solved that problem too. Now the EPA has had to dream up CO2 as a problem to justify their empire. The epa has to find another crisis to regulate.
What you refer to has a name: http://www.spunk.org/texts/places/germany/sp000711.txt
   / Ram1500 EcoDiesel V6 revealed! #655
It all came down to competition. The GM SUV's had independent rear suspension and the Explorer could not match the ride. They took the cheapest route and lowered the tire psi to 30 when Firestone warned against it. Some tire modifications, suspension tweaks, and there you have it. It would have been fine but as the tire pressure lowered due to improper tire inflation and blow outs roll overs occurred.
Long story short Ford took the cheapest route and Firestone should have refused to sell tires to them. And now we all have TPMS.
Chris
You contradict yourself
   / Ram1500 EcoDiesel V6 revealed! #656
How is that? Ford was behind the eight ball and had to do something to compete. I admit it was a blunder. No contradiction there.
Chris
   / Ram1500 EcoDiesel V6 revealed! #657
There's a lot of "unique" posters on this site. It's kind of amusing to see some people here post their own specific tweaky personal preference for what's important in a truck, and to post it in such a tone as if 300 million people across the country share the same views and wants.:rolleyes:
   / Ram1500 EcoDiesel V6 revealed! #658
Chris
A corporate decision to cheap out on a product and risk lives is, just that.
"Competition" is competition is just that, and in the hands of high morale companies and people- promotes excellence and quality.
   / Ram1500 EcoDiesel V6 revealed! #660
ANYWAYS.... Ram sells out initial production run of the ecodiesel in 3 days.
www.autoweek.com
just proving Dodge man's point
and i don't believe a 1/2 is a substitute for a 3/4 or 1 ton. the axles and suspension are beefier in a larger truck. and if you are towing 10K day in and day out would you want to be doing it near the upper end (or over) of the ratings (1/2 ton) or slightly more towards the middle (3/4, 1 ton)?
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
2020 Toro Pro Sweep Vacuum (A55787)
2020 Toro Pro...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
King Kutter TG72 Rotary Tiller Tractor Attachment (A55851)
King Kutter TG72...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
2025 XKH39 39in Hydraulic 4-Way Clamshell Skid Steer Bucket (A55851)
2025 XKH39 39in...
