Newbie looking for 1st welder
   / Newbie looking for 1st welder
So only the higher end helmets have the lower shades suitable for cutting and brazing?
   / Newbie looking for 1st welder #32
Either something happened in delivery, or it went to my spam folder which occasionally happens if it was emailed to me. I get several hundred emails a week at times. I'll go back and look and try to find it and reply.
Thanks Mark... got it now! :)
   / Newbie looking for 1st welder #33
The grind mode would be the clear or natural state and it would just lock it in.
Yeah, the grind mode is a switch on the inside that turns off auto darkening. You can see it in one of the views in the listing. The undarkened shade level is DIN 3.5 according to the manual. I haven't actually used the grind mode. I use a wire brush on the grinder to clean up slag and that doesn't make it darken.
   / Newbie looking for 1st welder #34
I don't think I would use a helmet in grind mode. Too cumbersome, view is too restricted, helmet might fall off if you bend over to check something and less comfortable than a simple face shield.
yes but it is convenient, if you want to just grind on something for a second, and then weld again.. just would be faster. I agree if I wanted to do some extensive grinding/shaping, it would be best to get out the clear shield.
   / Newbie looking for 1st welder #35
Your just not moving that brush fast enough!:D
Another question --
Anyone have a link to the current spec sheet or owners manual for the pa200st?
I'm looking for the I 1-eff rating or the max input amps so that I can I wire a dedicated circuit.
   / Newbie looking for 1st welder #38
Straight from the desk of the guy who "makes" this stuff up. Rated amps is 24. I1max is 38.8 (39).
  • PowerArc Brochure 2013.pdf
   / Newbie looking for 1st welder #39
The specs k0ua posted are for the standard 200. The 200ST has been reworked a little for better efficiency...either way I1max is not that much different.
1994 LUFKIN (A50854)
RIGID TOOLBOX (A50854)
2001 INTERNATIONAL 4700 (INOPERABLE) (A50854)
2001 INTERNATIONAL...
1984 GROVE AP-308 CRANE (A51222)
1984 GROVE AP-308...
Miller Bobcat 225G AC/DC Welder Generator Set (A49461)
Miller Bobcat 225G...
Land Honor Quick Attach Bale Spear (A50515)
Land Honor Quick...
