Newbie looking for 1st welder
/ Newbie looking for 1st welder
I also had no response to emails that I sent to the sales account last fall...
Just called them and ordered the powerarc 200 st :). I'll never be a able to find a mig welder for the difference in cost if I had gone with the imig 200 ($225) but I like the idea of a portable small inverter stick welder that I can bring wherever I want easily. And the sales guy felt the powerarc was the better choice for stick welding.
Next question -- harbor freight auto helmet or spring for something better?
/ Newbie looking for 1st welder #22
I don't have one of the harbor freight ones, but I do have one similiar from Northern tool. It works well, and from what I have heard of the Harbor freight ones, the owners report that they work well, and they can be less than $40 with a coupon. Are they going to be as good as a $300 dollar one, I don't think so, but I think they are OK.
/ Newbie looking for 1st welder #23
I wear prescription glasses which are a PIA with brazing goggles -- I'm thinking something like the miller elite with more shade choices(cut/grind mode) would be worth the money
/ Newbie looking for 1st welder #25
/ Newbie looking for 1st welder #26
I agree. I have both a good one and a HF model. There are differences but I think a hobbyist like myself could be happy with the HF if I didn't have the $300 version to compare it to.
/ Newbie looking for 1st welder #27
I have this one from Northern and I like it a lot. It takes regular AAA batteries which is a big plus for me. I've had the cheaper ones with the batteries spot welded in place and I've cut them out and replaced them but what a pain.
Northern Industrial Welders Auto-Darkening Welding Helmet with Grind Mode | Welding Helmets| Northern Tool + Equipment
Print this if you have a store local:
http://www.northerntool.com/images/downloads/stores/030313_coupon.pdf
for $52 if you print the coupon, I don't see how you could beat that. Mine does not have the grind mode, but I wish it did.
The title states it has a grind mode but then in the write up it only has shades 9-13 -- maybe it's a new feature?
I don't have a NT local here in maine so I'd be looking at ~$70 shipped. Still a good deal if it has the shades 5-6-7. As every other helmet with a grind and cut mode seems to be 200 and up.
/ Newbie looking for 1st welder #29
The grind mode would be the clear or natural state and it would just lock it in.
/ Newbie looking for 1st welder #30
I don't think I would use a helmet in grind mode. Too cumbersome, view is too restricted, helmet might fall off if you bend over to check something and less comfortable than a simple face shield.
So only the higher end helmets have the lower shades suitable for cutting and brazing?
/ Newbie looking for 1st welder #32
Either something happened in delivery, or it went to my spam folder which occasionally happens if it was emailed to me. I get several hundred emails a week at times. I'll go back and look and try to find it and reply.
Thanks Mark... got it now! :)
/ Newbie looking for 1st welder #33
Yeah, the grind mode is a switch on the inside that turns off auto darkening. You can see it in one of the views in the listing. The undarkened shade level is DIN 3.5 according to the manual. I haven't actually used the grind mode. I use a wire brush on the grinder to clean up slag and that doesn't make it darken.
/ Newbie looking for 1st welder #34
yes but it is convenient, if you want to just grind on something for a second, and then weld again.. just would be faster. I agree if I wanted to do some extensive grinding/shaping, it would be best to get out the clear shield.
/ Newbie looking for 1st welder #35
Your just not moving that brush fast enough!:D
Another question --
Anyone have a link to the current spec sheet or owners manual for the pa200st?
I'm looking for the I 1-eff rating or the max input amps so that I can I wire a dedicated circuit.
/ Newbie looking for 1st welder #38
Straight from the desk of the guy who "makes" this stuff up. Rated amps is 24. I1max is 38.8 (39).
  • PowerArc Brochure 2013.pdf
/ Newbie looking for 1st welder #39
The specs k0ua posted are for the standard 200. The 200ST has been reworked a little for better efficiency...either way I1max is not that much different.
2017 Ford F-450 Auto Crane 5005EH 2.5 Ton Crane Service Truck (A59230)
2017 Ford F-450...
2013 Ram 5500 Chassis Service Truck, VIN # 3C7WRNALXDG552597 (A61165)
2013 Ram 5500...
2014 Chevrolet Impala Limited Sedan (A59231)
2014 Chevrolet...
Rockport Mobile Command Center (A59230)
Rockport Mobile...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
(APPROX. 20) 4' X...
