EddieWalker
Epic Contributor
I started out with the Dremel version of the Multimaster and really liked how easy it was to make plunge cuts. Especially when working around baseboard, but it's also great on sheetrock and plastic. The Dremel blades are the drawback. They cost as much as the better brands, but last a quarter of the time. Fine Home Building did a test of blades and Bosch came out the clear winner. Nothing else was even close. Their version of the Multimaster is twice the cost of the Dremel and quite a bit heavier, but worth it because of how much better those blades are. $99 for the Dremel or $199 for the Bosch. I have both, but doubt I'll ever use the Dremel again.
For this job I think I'd start out with my sawzall and a really long metal cutting blade to cut through all the nails. Then see if the wood will just pull out.
Eddie
Eddie
