3 PT Dethatcher
   / 3 PT Dethatcher #1
Gittyup
Elite Member
Mid Atlantic
Kioti CK25 Shuttle Shift, loaded tires, JD X739
Anyone use one of these?
CMP 3-Point Dethatcher
Or know any thing about this company and this product. How well do 3 Pt dethatchers work vs. town behind? I like that I can raise and back into tight spots and drop it and let it do it's thing.
I get a lot of sticks and debris off my maple trees and thought his would be good, and maybe help with acorns too?
   / 3 PT Dethatcher #2
Unless you really need a de-thatcher a landscape rake would work better on sticks and such. Neither would do much on acorns.
   / 3 PT Dethatcher #3
It looks nice and is reasonably priced. Maybe I'll get one. I don't know if it will do anything for acorns and stuff.
I know my landscape rake is way to aggressive for the lawn. it will take the sticks, stones, grass, soil and everything else.
   / 3 PT Dethatcher
I have a nice landscape rake with gauge wheels. But, it's still too aggressive for grass. What about a pine straw rake? I think this would work on the sticks but how well will it pull up thatch? Yeah, I know the acorns are a tall order. There is a specialty tool that supposedly will gather acorns. Pricey for a one task tool, as I recall. My needs in order of importance are thatch, sticks/depris, acorns.
   / 3 PT Dethatcher #5
nope, but I've been looking for one.
Thanks for posting
   / 3 PT Dethatcher #6
None of those fixed dethatchers seem to do very well at dethatching... seems you need a power unit for that.
For what you want, it seems you'd be much better suited with a tow-behind sweeper. Unfortunately nobody seems to make an economical, heavier-duty version of the el cheap tow-behind lawn tractor sweepers, but I have one on my JD mower and it works very well.
   / 3 PT Dethatcher #7
I have a small Craftsman tow behind dethatcher now and it works well removing the dead grass.
Only issue I see is that its not a tow behind, but since its so close to the rear wheels, might not matter and won't need to add cement blocks to it to get it to dig down.
   / 3 PT Dethatcher #8
Really? I have one and even with cinder blocks on it, it leaves probably 75% of the thatch behind and still stuck. The tow-behinds look EXACTLY the same, must be my grass/ground which prevents it from working. The power dethatchers take almost all of it out, but try running one on 3 acres of grass :p
   / 3 PT Dethatcher #9
I made this to get up pine needles. I guess technically it is a dethatcher. It did rake up a big pile of pine needles. Probably have about $200 in parts, plus my labor, and the satisfaction that I built this. Overall it weighs in at about 60lbs.
The dethatcher that's linked at $269 + free shipping makes it a good deal. Looking at it the main thing I like about mine over this is that mine sits further back from the tractor.
20140218_155908.jpg 20140218_155847.jpg 20140215_142119[1].jpg 20140215_142051[1].jpg 20140215_142037[1].jpg 20140219_164656.jpg
   / 3 PT Dethatcher #10
Well, I'm not doing 3 acres :D, but I also don't cut the grass too short so not too much thatch to get up. The first time I did it, I did the entire lawn one way, went back and did it the other and then dragged it around every time I mowed for the month. By the second month, the lawn was the best its ever been. But that first day, boy did I pull up a lot of thatch.
That looks nice! Something about building things yourself always seems to install a bit more pride.
JOHN DEERE 330G SKID LOADER (A58214)
JOHN DEERE 330G...
2018 Honda Rubicon TRX500FA5 4X4 ATV (A59231)
2018 Honda Rubicon...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
