3 PT Dethatcher
   / 3 PT Dethatcher #1
Gittyup
Elite Member
Mid Atlantic
Kioti CK25 Shuttle Shift, loaded tires, JD X739
Anyone use one of these?
CMP 3-Point Dethatcher
Or know any thing about this company and this product. How well do 3 Pt dethatchers work vs. town behind? I like that I can raise and back into tight spots and drop it and let it do it's thing.
I get a lot of sticks and debris off my maple trees and thought his would be good, and maybe help with acorns too?
   / 3 PT Dethatcher #2
Unless you really need a de-thatcher a landscape rake would work better on sticks and such. Neither would do much on acorns.
   / 3 PT Dethatcher #3
It looks nice and is reasonably priced. Maybe I'll get one. I don't know if it will do anything for acorns and stuff.
I know my landscape rake is way to aggressive for the lawn. it will take the sticks, stones, grass, soil and everything else.
   / 3 PT Dethatcher
I have a nice landscape rake with gauge wheels. But, it's still too aggressive for grass. What about a pine straw rake? I think this would work on the sticks but how well will it pull up thatch? Yeah, I know the acorns are a tall order. There is a specialty tool that supposedly will gather acorns. Pricey for a one task tool, as I recall. My needs in order of importance are thatch, sticks/depris, acorns.
   / 3 PT Dethatcher #5
nope, but I've been looking for one.
Thanks for posting
   / 3 PT Dethatcher #6
None of those fixed dethatchers seem to do very well at dethatching... seems you need a power unit for that.
For what you want, it seems you'd be much better suited with a tow-behind sweeper. Unfortunately nobody seems to make an economical, heavier-duty version of the el cheap tow-behind lawn tractor sweepers, but I have one on my JD mower and it works very well.
   / 3 PT Dethatcher #7
I have a small Craftsman tow behind dethatcher now and it works well removing the dead grass.
Only issue I see is that its not a tow behind, but since its so close to the rear wheels, might not matter and won't need to add cement blocks to it to get it to dig down.
   / 3 PT Dethatcher #8
Really? I have one and even with cinder blocks on it, it leaves probably 75% of the thatch behind and still stuck. The tow-behinds look EXACTLY the same, must be my grass/ground which prevents it from working. The power dethatchers take almost all of it out, but try running one on 3 acres of grass :p
   / 3 PT Dethatcher #9
I made this to get up pine needles. I guess technically it is a dethatcher. It did rake up a big pile of pine needles. Probably have about $200 in parts, plus my labor, and the satisfaction that I built this. Overall it weighs in at about 60lbs.
The dethatcher that's linked at $269 + free shipping makes it a good deal. Looking at it the main thing I like about mine over this is that mine sits further back from the tractor.
20140218_155908.jpg 20140218_155847.jpg 20140215_142119[1].jpg 20140215_142051[1].jpg 20140215_142037[1].jpg 20140219_164656.jpg
   / 3 PT Dethatcher #10
Well, I'm not doing 3 acres :D, but I also don't cut the grass too short so not too much thatch to get up. The first time I did it, I did the entire lawn one way, went back and did it the other and then dragged it around every time I mowed for the month. By the second month, the lawn was the best its ever been. But that first day, boy did I pull up a lot of thatch.
That looks nice! Something about building things yourself always seems to install a bit more pride.
Hays LT-1 Tender (A56438)
Hays LT-1 Tender...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
2020 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A60429)
2020 CATERPILLAR...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A59228)
2025 HT360W Mini...
SKID STEER ATTACHMENT HAMMER (A58214)
SKID STEER...
