A couple of pics from England - my 5065e
   / A couple of pics from England - my 5065e #21
Yes A very nice setup. I can't say I like where they mounted your tool box but it wouldn't look any better on the rear fender where mine is on an American spec 5045E.
   / A couple of pics from England - my 5065e #22
I've been looking for a better place to mount a larger tool box. Can't say I'm impressed with either of JD's locations. I'm 6'2" and if I'm on the ground I can barely see into my fender mounted box.
I was considering making a bracket in the front where the suitcase weight hanger would normally go. Reaching around the loader isn't optimal, but I haven't been able to come up with anything else. Ideas?
Bill
I am 6'3" and never had an issue with the tool box in daily use. I do see how it could be an issue on the fender though. The only time I have a hassle with the current location is when I am filling up from jerry cans. It does get in the way a bit, but it's one of those things that I have just learned to live with.
   / A couple of pics from England - my 5065e #24
That is a pretty tractor!
   / A couple of pics from England - my 5065e #25
Why will JD not put tires that wide on the tractors of the same series in the US?
   / A couple of pics from England - my 5065e #26
At least the fuel tank won't melt on the UK version when the...(what is it?..) 3pth hydraulic relief valve melts it (or so I hear). :)
   / A couple of pics from England - my 5065e #28
Seriously. Those little skinnies they put on mine sure do help, but come on, this is America! Bigger is better!
By your sarcasm I take you think wider is not better. I guess it depends on what you're doing and the ground you're running on but around here wider is better. Then again you could ask Bobby Goodson of Goodson All-Terrain Logging what he thinks.;-)
   / A couple of pics from England - my 5065e #29
They match the tire size to the horsepower. It is pointless to have more tire then the tractor can make use of.
   / A couple of pics from England - my 5065e #30
No, I wish they were wider, especially when you have a bucket full of wet dirt from some bottom land and are trying to back out of it without sinking.
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
SET OF (4) BRAND NEW CHAINS AND BINDERS (A53843)
SET OF (4) BRAND...
378812 (A51573)
378812 (A51573)
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
