Yanmar 2210 lift arms too short for tiller
   / Yanmar 2210 lift arms too short for tiller #21
Your green tiller is an older RS1400. His red one is an RSB1400 or RSB1401. It's designed for use with a red Yanmar tractor's rear draft control socket. That's the reason for the different kind of mount. You can easily see what someone has done to solve the clearance problem on a tractor bigger than this tiller was designed for, yet maintaining draft control (the flex cable).
   / Yanmar 2210 lift arms too short for tiller #22
Here's the other end of the draft control squib. Anybody notice the top link config ?
   / Yanmar 2210 lift arms too short for tiller #23
100_6738.jpg100_6732.jpgI went out and measured my fabricated top link from pin center to pin center. Although adjustable it is set at 15-1/4". My tiller never hits the wheels, my chain case runs in a vertical position.
About a week ago I had a 1200 chain driven unit repairing and selling for a widow lady. I hooked it up and ran it by getting the top link the correct length. I don't understand why this is so complicated. I agree the correct way is the factory set up but it can be worked around. couple of pictures of it attached to my 2002d.
2210 does have 9.5-24 tires and I have 8.3-24 tires. Maybe that is the difference. No idea if the lift arms are the same?
   / Yanmar 2210 lift arms too short for tiller #24
I have the RSB1401 and it came with the toplink pictured in California's post (#8). I have very little clearance between the tire and the tiller, but it works great. If it matters, I have (13.50 - 16.1) R1 tires on the rear. I do have the draft control bracket on the tiller, but whatever linkage was there is long gone, and I'm pretty sure there isn't anything on the YM226 to connect it to anyway.
   / Yanmar 2210 lift arms too short for tiller #25
I see how a cable may give feedback to the hydraulic system for draft control.
But what we are talking about here, is geometry to keep the tiller from hitting the tires as it is raised. The cable can't help with that.
In your photos (enlarged below) I see a non-original quick hitch moving everything back a couple of inches. And likely extender tabs welded to the tiller to move its lift pins farther from its chassis. Is that a longer non-original driveshaft? Modifications like this are what some have done to use a Yanmar tiller but I don't think it replicates what Yanmar intended.
I don't understand the point you are trying to illustrate with photos 2, 3 in post #21.
   / Yanmar 2210 lift arms too short for tiller #26
Seems to me that it wouldn't be too difficult to fabricate that toplink using a standard toplink and some precision cut (CNC plasma cutter) steel, while still maintaining the adjustability. Would there be a market for such an item? If so, I can ask a friend. Welds wouldn't be pretty...but it would be solid.
   / Yanmar 2210 lift arms too short for tiller #27
Carey's pictures on Post #9 show clearly what's needed. That doesn't look hard to duplicate.
   / Yanmar 2210 lift arms too short for tiller #28
"I don't understand the point you are trying to illustrate with photos 2, 3 in post #21. "
I believe he is pointing out the existence, and lack of the stop brackets. If I were a welder I would install those stops and use a length of chain for the flexibility, otherwise a $20 toplink will work just fine.
   / Yanmar 2210 lift arms too short for tiller #29
Picture 055.jpgI could use a Reg. top link and actually tried it so I wouldn't have to Mount the Org. link but I never had Results Like this in the Pic.. Which was the first Turn of the Yr. effortless. You coluldn't adjust it to get these results. And if I recall If I you leveled the Tiller it would hit the Rear tires. There a reason Yanmar used the Top Link setup and I would not even consider Not using it unless I had to. But of course different model Tractor,Tiller etc. different results. When I bought mine From Fredricks I was told the Rs1400 is what my YM2000 was intended for.And BTW. not much mention of this but I really like seeing the Yanmar of America on Fredricks Refurbished Dealer Adds. :):thumbsup:
So bottom line is there's more than one way to till a garden. :)
I checked last night and confirmed that it is a RSB1400.
I found a little place in the cast gearbox that says 90# and .72L so I'll drain the oil to make sure it's not full or water or something.
I don't want to do any permanent modifications since this isn't 100% my tiller. I also don't want to track down and buy a bracket when I have the parts to make this work. So as I see it my options would be....
-buy original bracket and short link
-make bracket and short link
-make bolt on extension brackets, use a standard top link and the PTO shaft that was with it
-make more extensive mods to push out from tractor
-use a custom shortened top link to rotate the top of the tiller forward and the bottom away from tires
-other mods
I will see how the brackets I'm working on work out and if that's not enough I'll mod one of my worse condition top links. Just for reference, the bolt to the aft of that lower mount is 5/8" and the lower pin holes are 3/4" so swapping the tubes would be a lot of work and you'd still have to modify to make work.
Also in the picts of the green tiller, those pieces of steel that go to the lower attachment points look more like gussets to me than stop plates but that's just my interpretation...
2020 UNVERFERTH 332 LOT NUMBER 199 (A53084)
2020 UNVERFERTH...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
ALLIANCE 480/80R42 LOT NUMBER 134 (A53084)
ALLIANCE 480/80R42...
Kubota LA853 Loader Arm (A51691)
Kubota LA853...
2017 John Deere 8345R MFWD Tractor (A53342)
2017 John Deere...
