Gannon Box Blade with hydraulic rippers
   / Gannon Box Blade with hydraulic rippers
Brian,
Both the top and bottom pins are 3/4"
I have another question....What are the pins called the hook the top link to the tractor. The one on my tractor seems to be cat 2 on left side and cat 1 on the right. A friend of mine has one that can be used as a cat 2 pin and then the end of it has a cat 1 pin. I feel so lost when it comes to some of these terms.
   / Gannon Box Blade with hydraulic rippers #23
I'm very new to the tractor world. I'm not familiar with what a side link is
Top & tilt cylinders. Top link, side link, makes grading soooooooooooo much nicer. ;)
I only have 1 rear remote. Seems like you would have to have several more remotes to run all that stuff. Where do you put all the additional controls for all the rear remotes.
   / Gannon Box Blade with hydraulic rippers #25
Your tractor can have 2 OEM remotes, but that is often not enough. Just for a Gannon with hydraulic actuated rippers and "T&T" you need 3. And often even more. Then you can do something like what I did on the back of my Mahindra 3215. I now have 4 sets.
   / Gannon Box Blade with hydraulic rippers #26
Do you have a picture?
UPDATE......... I have had the hydraulic cylinder installed for about a month. It works flawlessly....Thank you very much Brian
   / Gannon Box Blade with hydraulic rippers #29
Glad it all worked out for you. I'm sure you are enjoying that beast of a box blade. I know I sure like mine.
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
11' CONTAINER (A52706)
40 Dry Van Enclosed Trailer (A54865)
40 Dry Van...
EZ-GO Cart (A55853)
EZ-GO Cart (A55853)
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
FAKE (A52472)
FAKE (A52472)
