Gannon Box Blade with hydraulic rippers
   / Gannon Box Blade with hydraulic rippers
Brian,
Both the top and bottom pins are 3/4"
I have another question....What are the pins called the hook the top link to the tractor. The one on my tractor seems to be cat 2 on left side and cat 1 on the right. A friend of mine has one that can be used as a cat 2 pin and then the end of it has a cat 1 pin. I feel so lost when it comes to some of these terms.
   / Gannon Box Blade with hydraulic rippers #23
I'm very new to the tractor world. I'm not familiar with what a side link is
Top & tilt cylinders. Top link, side link, makes grading soooooooooooo much nicer. ;)
I only have 1 rear remote. Seems like you would have to have several more remotes to run all that stuff. Where do you put all the additional controls for all the rear remotes.
   / Gannon Box Blade with hydraulic rippers #25
Your tractor can have 2 OEM remotes, but that is often not enough. Just for a Gannon with hydraulic actuated rippers and "T&T" you need 3. And often even more. Then you can do something like what I did on the back of my Mahindra 3215. I now have 4 sets.
   / Gannon Box Blade with hydraulic rippers #26
Do you have a picture?
UPDATE......... I have had the hydraulic cylinder installed for about a month. It works flawlessly....Thank you very much Brian
   / Gannon Box Blade with hydraulic rippers #29
Glad it all worked out for you. I'm sure you are enjoying that beast of a box blade. I know I sure like mine.
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
30008 (A53424)
30008 (A53424)
2012 Club Car Precedent Electric Golf Cart (A53424)
2012 Club Car...
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
2005 Chrysler Town and Country Limited Van (A55853)
2005 Chrysler Town...
VERMEER STR48 - 48" MINI HYD TRENCHER (A52706)
VERMEER STR48 -...
